Old 04-18-2008, 11:28 AM
AntonioE AntonioE is offline
Smile Replacing Headlamps
Hi there. I have a 2001 3.1 Pontiac Grand Prix, and both the headlamps of it are cracked, so I have just bought a new pair of them, OEM original. The question is if it is too hard to change them by myself, I have changed the lights bulbs on both lamps, but it is surely much more work to change the hole set of headlamps, including the corner lights on both. Can I do it myself or should I send it to someone with more experience?
Thank you!!!
Old 04-18-2008, 12:39 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: Replacing Headlamps
it really isnt hard. there are 2 bolts holding the assembly in. i cant remember exactly what size they are. i believe the are 10mm. just remoove the 2 bolts and slide the assembly out. the only bi*ch of a part is getting it back in
Old 04-18-2008, 12:49 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Very simple job. The headlamp assemblies come off the car with just 2-10mm headed bolts that attach through the top. If all you received was the lenses, they detach from the adjusters/brackets via some screws through the back side. Should take less than an hour to do both sides.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-18-2008, 06:15 PM
Smile Re: Replacing Headlamps
Thank you guys. I'll give it a try and I'll let you knoew the outcome!!!
