Old 04-18-2008, 08:49 AM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
getting stuck in 4 low
i have a 99 4.3 s10 blazer with the auto 4wd option i dont know what transfer case it has. I use the utility part of the S.U.V the most lots of pulling heavy loads like downed trees and such, but my problem is every now and then when i use 4 low it dosent come out there are no codes present and ive tryed rocking back and forth and that sort of thing
any help would be greatly apreciated
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 04-18-2008, 09:03 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: getting stuck in 4 low
We need to ID your transfer case first.
Does you 4W buttons have the auto button?
Also a id tag on the back of transfer case.
233-236 or other.
Post back id.
MT
Old 04-18-2008, 09:06 AM
Old 04-18-2008, 02:27 PM
MT-2500's Avatar
AF - Advisor
If a 236 transfer case you will need a transfer case/transmission capable scanner to get codes or check or test it out.
Got of good shifting test and info in a good capable scanner.
Post back any codes.
MT
MT
Old 04-19-2008, 08:57 AM
not to be an a@# but did you even read my post, there are no codes present
Old 04-19-2008, 10:34 AM
MT-2500's Avatar
AF - Advisor
Yes I did read your post.
Your post are very short on info but from you having the auto shift button I asume you have a 236 transfer case.
Did you check the ID tag to be sure?
Did you read my no 4 post back?
As stated you need a transfer case capable scanner to get transfer case codes or test the shifting.
99 times out of a hundred you will have codes past present or stored if it is not shifting right.
Tell us how and what kind of a scanner did you used to check for codes?
MT
Old 04-19-2008, 01:30 PM
iits is a 236 and i used the good old fashion snap on red brick
Old 04-19-2008, 02:10 PM
MT-2500's Avatar
AF - Advisor
Red brick is my middle name?
What cartiage are you using?
OBD11 or engine specific?
Did it communicate with the transfer case and body and transmission computers.
Any readings on transfer case module?
MT
MT
