Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 04-18-2008, 08:21 AM
Bunky1267 Bunky1267 is offline
Question 95 APV Window?
We have a 1995 APV and the previous owner took the window regulator out of it, we are going to put a new one in but don't have access to the Big pop rivet gun, Has anyone tried using Bolts??
Old 04-18-2008, 09:24 PM
lola_621 lola_621 is offline
Re: 95 APV Window?
I would rent the rivet gun it only takes a few minutes to use ,bolts will not work-too small of an area.
Old 04-19-2008, 06:57 AM
LMP's Avatar
LMP LMP is offline
Re: 95 APV Window?
High
Is the APV a recent acquisition? (in addition to Trailblazer and Silverado?
Just if it helps, when needed, you have access to a lot of files here
www.avigex.ca/xport, including www.avigex.ca/xport/regulatorfig6.jpg www.avigex.ca/xport/regulator.jpg
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 05-21-2008, 06:18 AM
frjber1 frjber1 is offline
Re: 95 APV Window?
3/8 hex head bolts 5/8 long 3/16 diameter with a washer and a lock nut
Plenty of clearance - works fine no need to rivet replacements
We own the Lumina APV van 1995, first the passenger side auto window motor quit and later the drivers side I went to the auto salvage yard and got the manual crank assembly this was an somewhat easy removal as the inside of the doors are the plastic/fiber glass and can be cut apart
When home I simply drilled out the rivets then did the same to the auto assemblies in the doors, the door panels had a marking for the manual window crank so I did not have to measure for the hole
