Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 04-18-2008, 01:03 AM
btroy btroy is offline
2k: oil leaking out bottom
Hi I have a 2000 Cougar and notice oil has been leaking out the bottom of the engine at a rate of about 1 quart every 3000 miles. Anyway I looked under there and see oil dripping from the botom pan(I think it is a pan)
I realize it could be a real seal or an oil pan gasket.
I work on alot of older V6 and V8 and not real sure how this engione/trans combination goes together.
How hard is it to replace the oil pan on one of these Cougars?
Can the oil pan be replaced while the engine i still in the car?
It is a V6.
It has a manual transmission.
Troy
Old 04-18-2008, 08:45 PM
Blaiser17 Blaiser17 is offline
Send a message via AIM to Blaiser17
Re: 2k: oil leaking out bottom
I just replaced my oil pan 2 weeks ago. On my 2000 Cougar V6 which is also a manual. Only hard part was removing the Y-pipe. Depending on how rusted your bolts are that should be the only issue. It can be done under the car.
Good luck buddy
1999 Chevy Monte Carlo 3.1L
1991 Chevy Camaro 3.1L
1981 Chevy Camaro z28 383 Stroker
2000 Mercury Cougar v6
