Grand Prix 2000 A/C Condenser
I have to replace my A/C condenser. Will I need new O-Rings or Gaskets?
Is there a special procedure to replace the Condenser ? Thanks Andy
Re: Grand Prix 2000 A/C Condenser
The lines at the condenser use o-rings. This is not a fun job and a real PITA. You plan on doing the work DIY instead of having a shop do it? In order to remove the condenser you'll have to remove the radiator, dog bone engine mounts, cooling fans and everything else in the way.
Also, unless all of the R134a has leaked out you'll need to evacuate any of the remaining R134a out of the system. After the condenser is replaced and everything is back together before adding back the R134a you should run a vacuum check to insure there are no leaks and remove any possible moisture from the system. Plus be sure to add approximately 1 ounce of PAG oil directly into the condenser input line before installing it and the refrigerant lines.
You will need to pull a vacuum on the system down to 29" of mercury. This will boil off any moisture that may be in the ac system. This needs to be done in order to stop the moisture from freeing up the system.
Also doesnt moisture mixed with r134a create acid and corrode away your AC system from the inside out? Thats what I heard
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
i agree with comments but if u no the parts are bad & want to save $$ install them then take it to shop 4 the recharge.im assuming system is empty
Duh! Must have had a brain fart there for a second. HA HA Heating and AC was the last class I took for my degree, did pretty good in it too. Funny how fast one forgets things....
