Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 04-17-2008, 06:36 PM
troy808 troy808 is offline
Need help 2003 galant v6 auto. no idle
Hi all.. I am helping a friend out with his problem. The vehicle does not idle. Service engine light was on so I hooked up the scanner. Found 2 codes p0340 and p0335 cam sensor and crank sensor fault. Called the dealer and they told me that this Vehicle does not have a cam sensor. Any how My friend decided to replace the crank sensor. Same problem no idle and is reading 20 degrees advanced. what do you think the problem is? Do you think the pcm needs to be reprogrammed/flashed? Do you think the cam sensor is built into the distributor? do you think the T belt jumped?
Any advice would be appreciated. Aloha....
Old 04-18-2008, 03:03 AM
sparkeykev sparkeykev is offline
Send a message via Skype™ to sparkeykev
Re: Need help 2003 galant v6 auto. no idle
Perhaps a faulty idle air control valve
Old 04-23-2008, 05:28 PM
Wouldnt that throw a code of some sort? I am still stuck ..someone please help. I ve read that a 2002 v6 galant has a cam sensor. Does the 03 have one and if so wher is it? ALoha
Old 05-19-2008, 02:44 PM
acorral312 acorral312 is offline
I'm having the same problem....I replaced the crank sensor and the problem continues...its throwing p0335, p0340, and p1400. The car dies while idling.
Old 05-20-2008, 10:43 AM
Anyone know a fix to this problem?
Old 07-03-2008, 01:51 AM
dukowski's Avatar
dukowski dukowski is offline
try this link.
http://autorepair.about.com/library/faqs/bl910h.htm
