Go Back   Automotive Forums Car Chat > Mercury > General Discussion
Old 04-17-2008, 03:33 PM
jlbrokaw jlbrokaw is offline
91 capri xr2 wont crank over
I just replaced the oil pressure sender with a mechanical one, and now the car wont even crank over. any idea as to why? I can't find any loose connections/shorts so i dont think thats the problem. The fuel pump kicks on still so I dont think it's because the ECU wont let the starter kick over. I dont even hear the cylenoid kick. nothing.. any help would be appreciated.
1996 Isuzu Rodeo 3.2 4x4
1991 Mercury Capri XR-2
Old 04-22-2008, 09:12 PM
rhandwor rhandwor is offline
Re: 91 capri xr2 wont crank over
What did you do with the existing wiring. I would leave the old one hooked up and install the mechanical one some where else. You must have grounded something when you made the change.
Old 04-22-2008, 09:15 PM
Acutally, the problem was quite simple. My dad pulled the old sender out and knocked off a wire from the starter cylenoid. I hooked the wire back up after discovering the problem and she runs like a charm now with the exception of the turbo wich seems to have a blown oil seal internally.
