Old 04-17-2008, 01:19 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Engine Running Very Rough
I came out this morning to go to the doctors office. When I started the car it started right up but it began running rough. The idle will drop and rise sporadically. I think it's running rich as it stinks of what I would say is fuel while it's running. Also, it does not throw a CEL.
All that has changed recently was that I took off the BCS to pull the plug and broke it. I got another one and put it back on. That was yesterday and it ran fine after I put the new BCS in. I also cleaned the MAS this weekend.
So, I can only suspect a few things right now, but I'm not sure. Please tell me you guys know what's up.
Old 04-17-2008, 03:39 PM
new2mitsu new2mitsu is offline
Re: Engine Running Very Rough
that seems really similar to what my car did when my ECU took a dump
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 04-17-2008, 04:58 PM
Hans_GZP Hans_GZP is offline
Yes, check the caps in your ecu as well as the honey combs in your maf sensor.
94 Dodge Stealth TT
94 Dodge Stealth TT, pearl yellow, for sale
93 3000GT VR4, stock, for sale, red
96 3000GT Spyder SL, black, stock, might sell
97 3000GT VR4: stock, for sale, red
92 Galant VR4: TBE, bunch of crap
95 Montero SR: run stuff over vehicle
Old 04-17-2008, 05:16 PM
Polygon's Avatar
The Red Baron
I forget where the ECU is and the MAF mesh is dented in one spot but has been since the day I bought it.
Old 04-17-2008, 05:29 PM
Pull off the side carpet panels on the center console. You will see the ecu behind the radio. 3 10mm bolts hold it in and 3 plugs go into the ecu. Undo that stuff and pull it out. 4 screws to take off the ecu cover and you are now looking at the circuit board. Check around the 3-4 capacitors that are on the board to see if they are leaking anything.
94 Dodge Stealth TT
Old 04-17-2008, 05:41 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Hey polly.. just come over and swap them out and see what fixes it..
Jason
Old 04-17-2008, 05:50 PM
Polygon's Avatar
The Red Baron
Only problem is that I just went out to pull the ECU and I can't bend over that much to get it out since they cut me open again yesterday at the doctor's office.
Not to mention that I wouldn't want to drive it the way it is running. I barely made it to Orem yesterday on the epoxied boost solenoid.
Now, wouldn't I at least get a CEL if the ECU decided to bust a cap, no pun intended.
Old 04-17-2008, 06:16 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Not necessarily.
Old 04-17-2008, 06:54 PM
Polygon's Avatar
The Red Baron
Bugger.
Well, I suppose it's not far off since the MAF isn't throwing a code either. Now it's just a matter of getting it out.
Old 04-21-2008, 10:17 PM
Polygon's Avatar
The Red Baron
Well, I got another MAS and put it in. The car started right up and idled like normal. However, I was getting a lot of white smoke and it stunk like sulfur. So, I'm wondering if from running rich I had some fuel in one of the cats. After the engine warmed up it stopped? Also, there was a noise, sounded like metal rattling around near the passenger wheel that also went away once the engine warmed up.
Despite that it is idling better than before.
