Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 04-17-2008, 09:36 AM
jnevilles jnevilles is offline
Vacuum Routing-88 Bronco full size
Hi, I have a full size 1988 bronco 5.8 (351). A vacuum line came loose, and I cant find where it goes. If someone could look under their hood, they might be able to help me. On the left side of the engine (passenger side), and to the right of the canister, there is a black three way valve (about size of a silver dollar). It has three vacuum lines running from it. Two are long and one is short. The short one came loose, and I can't find the connection point.
Any help will be appreciated.
John
P.S. The original engine compartment vacuum diagram is 75% damaged (unreadable).
Email: [email protected]
Old 04-22-2008, 07:58 PM
rhandwor rhandwor is offline
Re: Vacuum Routing-88 Bronco full size
Look for a vacuum diagram around the schroud for the fan.
Old 08-13-2008, 07:29 AM
clate clate is offline
My Broncos at home so I can't look at this moment,I don't drive it to work, but I would check in the harness with the multiple lines for a broken end. I don't think the line you're looking at a line that came loose, I think you are looking at the shorter section of a longer line that became brittle and broke. I had one line break a few years ago, when I went to splice it back together I checked the other lines and they easily broke with minimal pressure because they were so brittle. I bought about 12 feet of vacuum line and replaced all of the lines. Most of them go from that carbon cannister to back behind the engine and connect to the manifold or TB.
Hope this helps.
1965 StarCraft Seafarer
1989 Full Size Bronco ( stays at the beach )
1999 Quest ( pulls StarCraft to the water )
2003 Taurus SES ( gets me to work )
Old 08-13-2008, 08:24 AM
If you find a short piece as mentioned in the previous article. I use a short piece of vacuum hose which fits tightly on this tubing to make a splice.
