Window washer comes out of Door?
sounds weird but when you go to wash the back window the washer fluid comes out of the passanger Door and all over the inter.....any way to Cut the line to the back?, geting tired of cleaning up the mess, it's making the carpet stink
Re: Window washer comes out of Door?
If you open the hood and look under the cowl plate, above the strut assembly on the passenger side corner, you will see 2 rubber hoses that are the window washer fluid lines. These come from the washer fill tank. One goes to the front washers, the other, to the back washer. You should be able to pull the back one loose from its in line connector and plug it to stop the washer fluid leak, if thats what your looking to do and not repair the cut line.
