Go Back   Automotive Forums Car Chat > Peugeot > 307
Old 04-16-2008, 11:50 AM
msmurf1962 msmurf1962 is offline
Question washer pump fuse
I am new to this so here goes. I was on my way home and tried to clean my windscreen and found that both front and back washers not working. I have checked the level of water and it is full. I have tried to find a fuse for the washer pump with out any luck, can someone help me please i have a 307 HDI 03 registered.All help will be grateful.
Old 05-01-2008, 05:16 AM
romg307 romg307 is offline
Re: washer pump fuse
The problem isn't a fuse. I had the same problem, and eventually tracked it down to the actual pump not working any more. It's not too expensive to buy a new pump, it's just a hard job getting to it. It's located under the Water container, but you have to get to it by removing the wheel arch cover over the Right hand front wheel. Unless you're insane like me, don't remove the Water container itself. Really hard to get back in. Hope this helps.
