Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 04-16-2008, 09:58 AM
rell2tru rell2tru is offline
Starting/Acceleration Problem for '96 OLDS 88 Part 2
Let me be brief and clear:
Problems: When car sits between 30 mins and an hour, it struggles to start as if it was starving for gas. When I sit in idle for about 5 mins or so (waiting for someone for example), car tends to make little ticking noises around muffler area; then when switched to drive after idle, blue smoke is shot out. When trying to drive off hesitation, engine light flickers on and off until stuck on. Not sure if it's an "idiot light" or not.
Key things to know:
Tune-Up done last January
Fuel Filter is rusted out.
Gas Mileage is declining (can get 250 miles/gal. within city orginally; now around 200-225).
4 possibilities:
1. MAF sensor
2. O2 sensor
3. Fuel Injector Problem
4. Ignition Misfire
All I know is that it is fuel related. Any help would be greatly appreciated. Thanks!
Old 04-16-2008, 03:00 PM
maxwedge maxwedge is offline
A990 racer
Re: Starting/Acceleration Problem for '96 OLDS 88 Part 2
Questions, what is the cel code, have youy checked fuel pressure when this happens?
Old 04-18-2008, 08:38 AM
I haven't checked the fuel pressure. I don't know where to go to get it checked out besides getting my car "diagnosed". Any places in mind?
Old 04-18-2008, 02:57 PM
A990 racer
Any repair shop has a fuel pressure gage, or buy one for about 55-60 dollars.
Old 04-21-2008, 08:59 AM
I called around and some places do daignostics and some don't. NAPA said they do theirs for $49.95. Does the gauge read by RPM? If that's the case, I'm assuming under a specific level, then something is obviously wrong and I'm hoping it's just the fuel filter and not the pump, O2 Sensor, or MAF.
Old 04-21-2008, 02:47 PM
A990 racer
Fp is regulated by enginevacuum/load.
Old 04-21-2008, 03:38 PM
OKay....I was actually going to get it tested today, but 20 mins later after going somewhere and it stalled on me and had to get a tow home. You know what else it might be?? The carburator. I'm hoping not both the fuel pump and the carburetor. Is there a carburetor test machine too?
Old 04-21-2008, 06:54 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Sorry, no carburetor on your car, it is fuel injected (MPI). Did you check for spark when it stalled? Will it start after the engine cooled down? You have to check for spark & fuel when it don't start!
Old 04-21-2008, 09:30 PM
My engine wasn't overheating or anything like that, the temp was just fine. After I had my car towed home, I just let it sit for a couple hours, then started it and it was acting like it was about to struggle again, but actually it was fine. So it's definitely either the fuel pump or filter...it was driving as if it was starving for gas and needed a tune up (which I got last January). I didn't check for spark though.
