Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-16-2008, 12:05 AM
96cutlasssupreme 96cutlasssupreme is offline
replace 96 cutlass engine & trane w/91 Lumina
Here is a some background info. 96 Cutlass first had overheating issues changed out the whole cooling system, pump, radiator, temp sensor, thermostat (3) etc. Still hot. Then the tranee began to go. won't accelerate correctly. 1st & 2nd slow rise with high rpm. I believe that the 1 & 2 shift solnoid was bad the entire time and was the cause of the overheating. I have acquired a 91 Lumina and want to attempt to pull the engine & trans and put into the 96 cutlass. Here is my question. What issues/complications, if any, might arise when doing the change? Your knowledge will be greatly appreciated.
Old 04-16-2008, 02:55 PM
maxwedge maxwedge is offline
A990 racer
Re: replace 96 cutlass engine & trane w/91 Lumina
Welcome to AF. Not a direct swap, subframe, axles, wiring harness and pcm are just some major differences, I wouldn't do this you are going backwards.
Old 04-16-2008, 07:30 PM
kwk39018's Avatar
kwk39018 kwk39018 is offline
the newer 3.1s are better any ways.(95 and newer). They have more hp and torque. I would fine a newer motor if i were you. It will be a lot easyer.
It might a pos, but its my pos.
Old 04-25-2008, 01:20 PM
Thank you for your comments.
