Old 03-03-2003, 05:13 AM
Davoaldo Davoaldo is offline
Shiny Models??
I got some turtle wax one step cut-n-shine thing today and used it then used tamiya wax to finish it off but i still can't get the shine ppl get. Like i c ppl get shine liek real cars. Am i doign soemthign wrong??
heres the pic of it before and after
Before
Old 03-03-2003, 05:14 AM
after
Old 03-03-2003, 05:17 AM
Veyron's Avatar
Veyron Veyron is offline
Smile
One reason is, it doesn't look like you clear coated it. If you didn't you're never going to get metallics, pearls or mica's to shine, you must clear coat those types of paints.
Old 03-03-2003, 05:33 AM
ahhhhh crap i forgot about that bit..... will do for my next one :P
oh i also get these circle scratches when lookign at it in different angle can that be fixed as well??
and yeah i've read the FAQ
Old 03-03-2003, 06:37 AM
exhaust smoke's Avatar
exhaust smoke exhaust smoke is offline
If you're gonna clear coat the R34, remeber to give it a scub with a little detergent on a sponge or something. If you apply clear straight on top of the turtle wax, the paint may react with it.
Old 03-03-2003, 06:50 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Since it's metallic, I recommend clear coating, and sand the clear layer with fine sand papers such as 2000 grit and above.
Sanding and polishing process looks like this.
http://www.automotiveforums.com/vbul...999#post578999
P-man has a complete step by step guide, so check FAQ for more.
Hiroaki Fukuda
Old 03-03-2003, 07:04 AM
Hiro, what compound do you use?
I use Automotive rubbing compound, but it doesn't always produce sucha a deep shine.
Old 03-03-2003, 01:08 PM
primera man's Avatar
"P-Man"
Have a read here
View All My Models Here.
Old 03-03-2003, 05:47 PM
D[X]P's Avatar
D[X]P D[X]P is offline
Send a message via ICQ to D[X]P Send a message via AIM to D[X]P
hey cool car
whats the scale,how much $$,and who produces it?
Failure is only the opportunity to begin again more intelligently.
Old 03-03-2003, 11:54 PM
what car??
its a skyline r34 1:24 tamiya and i made it...
its not as good as ppl i c here but i'm trying to get better....
Old 03-05-2003, 06:09 PM
D[X]P's Avatar
cool i see
umm i dun get it-why sand the clear coat?
Old 03-06-2003, 07:28 AM
hirofkd's Avatar
Maybe the sanding isn't enough? Like, there are still some spots that hasn't been eliminated?
After I sand the surface with 2000 grit Tamiya finishing paper, I use Detail Master's polishing abrasives, from 4000 to 12000.
Then, polish the surface with Tamiya. This should give you a sufficient sheen.
Just for self satisfaction, I use Modeler's Top Compound, and Hasegawa's ceramic compound after Tamiya.
Then, I wax the surface with Zymol auto wax. (or Tamiya wax or Hasegawa polymer wax)
Hiroaki Fukuda
