Old 04-15-2008, 12:46 PM
JeenyusVR4 JeenyusVR4 is offline
Crank no start
Ok so it started about 4 days ago when i turned off my car my fuel pump would stay on and i couldnt get it to turn off. I was in a hurry for work so i took my other car and just disconnected the negative battery terminal to stop the fuel pump. Later that day when got home i put the cable back on the battery and started my car and when i turned it off my fuel pump turned off just like normal. So i thought that was kinda weird but i drove my car the whole rest of the day with no problems. But the next day i went out to my car i went to go to start it and i had no power at all, not even dash lights. So i charged up my battery and now my car cranks but wont turn over. I think it might have something to do with the fuel because i cant hear my fuel pump at all when im cranking and i have a walbro 255 so you can hear it when its working. does anyone have any ideas on what it could be other than just i new fuel pump. Or how to check the fuel pump operation????/
Old 04-15-2008, 01:42 PM
new2mitsu new2mitsu is offline
Re: Crank no start
are you getting power to the fuel pump? should be able to check with just a volt tester...
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 04-15-2008, 04:37 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Re: Crank no start
You sound to be having a short on your fuel pump circit somewhere, if I were you d do a bit of searching for it and if you cant find it, go ahead and upgrade, wire in a new switch for the fuel pump for added securty, its a common mod f you do some searchng. but dont keep wasting batteries in the mean time.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 04-17-2008, 05:25 PM
Hans_GZP Hans_GZP is offline
Re: Crank no start
If it's a turbo, check your fuel pump relay in the engine bay. Also, check your caps on your ecu. Post up your model and year and I can help you out more.
94 Dodge Stealth TT
94 Dodge Stealth TT, pearl yellow, for sale
93 3000GT VR4, stock, for sale, red
96 3000GT Spyder SL, black, stock, might sell
97 3000GT VR4: stock, for sale, red
92 Galant VR4: TBE, bunch of crap
95 Montero SR: run stuff over vehicle
