Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-14-2008, 07:50 PM
msb2026 msb2026 is offline
92 eclipse 2.0 engine problems
ok guys maybe some body can help me out i just bout a 92 eclipse 2.0 non turbo the engine does not run good at all it sounds like its missing at idle and when you rev it the valves are real loud but when the rpms are high it kind of slacks off i also have a 90 laser 2.0 turbo that i kind of compare the engine sounds to something is wrong with the eclipse it had a light the code told me it was the tps so i replaced it and now i have no light ive changed the plugs gapped at 0.44 new wires new pcv and a new tps what else could it be
Old 04-14-2008, 08:05 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: 92 eclipse 2.0 engine problems
Welcome to AF. Please try type in complete (or somewhat complete) sentences so it's readable, it makes it much easier on us. With that being said, have you checked the the timing? If the timing checks out good, I'd pull the oil pan and check to make sure you don't have rod knock. The only reason I say that is you say the "valves" are real loud, but if you heard the valves, the car would not run for more than about 10 seconds before it would kill.
Do some routine maintainence and check the things I suggest before you drive it anywhere.
Also, it helps to put your car info in your signature so you don't have to type it out every time you post. (Year, make, model, tranny, mods, etc)
95 Talon TSI AWD
97 Eclipse GST
Old 04-15-2008, 07:29 AM
yes ive checked the timing it seams to be ok.im pretty sure its not a rod knocking it is the valves makiing the sound
Old 04-15-2008, 11:58 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Pull the valve cover and inspect the head. Maybe you have a worn cam or something. Look for physical damage. Also check for metal in the oil.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-15-2008, 04:45 PM
ok guys i completed a compression test heres what i got.
1......85psi dry 90 wet
2......25psi dry 30 wet
3......155psi dry didnt test wet
4.......175psi dry also didnt test wet
ok ive done some reading on the internet and it gave me the idea
that its most likely ether bad valves or a bad head gasket? what do you guys think..who and i dont want to forget to say the car does run as long has i want it to. ive also checked the cam timing marks along with the timing with it running!!!! any help will be great!!!
Old 04-15-2008, 06:22 PM
One more thing guys is there anything else it could be other then a bad headgasket or valves
92 eclipse GS 2.0 non turbo 5speed
90 laser RS 2.0 turbo 5speed
pics coming soon
Old 04-15-2008, 06:42 PM
Bad rings would cause low compression. See if you can get ahold of a leak-down tester to see what's leaking. If you open the radiator cap and see bubbles, it's most likeley a HG, if you hear air coming from the dipstick tube, it's most likely rings, if you hear air coming from the intake, it's most likely intake valves, if you hear air coming from the exhaust, it's most likely exhaust valves.
95 Talon TSI AWD
97 Eclipse GST
Old 04-15-2008, 07:39 PM
Holset powered 420a
Thats a good test to perform to see whats wrong. Sounds like your in mine same position. Except you have more compression than I do. I still drive mine everyday, it has been running that way for almost 2k.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-16-2008, 07:30 PM
well i started taking it apart today i dont have any broke springs aleast that i can tell ive toke the timing belt off and the exhaust off im going to take off the intake tomorrow and remove the head im hoping it just a bad head gasket or valves
pics coming soon
Old 04-16-2008, 08:34 PM
Holset powered 420a
You should do a leak down test before you pull the head. It will give you a better idea of whats wrong.
98 Eclipse GS Turbo
2001 BMW 325i - DD
