Old 04-14-2008, 04:29 PM
Dunamis Dunamis is offline
Question about OBD1 on 95 K1500
At this point in time, when I hook up a jumper wire to my OBD1 jack, I get no codes (flashing SES light). If I go to a garage and hook up to a diagnostic computer will it pull different types of codes for my truck, other than the flashing SES light) or will they simply go off of the flashing SES light to determine if something else could go wrong in the future?
Old 04-14-2008, 04:35 PM
Re: Question about OBD1 on 95 K1500
Let me clarify, I get the usual code squence "12-12-12". So to say I get "no" codes isn't quite right.
Old 04-14-2008, 04:39 PM
J-Ri's Avatar
J-Ri J-Ri is offline
They would more than likely use a scan tool to retrieve codes. They could use the paperclip method, but I always use a scan tool.
Is your SES light on? What do you mean "if something else could go wrong in the future?"
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-14-2008, 05:04 PM
Basically, do garages use scan tools to diagnose symptoms your car may have, even though they may not be severe enough to trip the SES light? Or would they go solely off of your car shooting out codes?
No my SES light isn't on...
Old 04-14-2008, 10:35 PM
After reading my post I realize how confusing it sounds. Let me simplify it like this:
-Does the OBD1 scanner that garages use for 95 model and below supply the different codes that you can't get with the paperclip?
- Does the computer on truck supply more indepth information that can only be pulled out by a scanner?
Old 04-15-2008, 07:52 AM
Jeremy-WI Jeremy-WI is offline
I don't know if there are any codes other than what would be reported with the paperclip method.
There are powertrain parameters that can be looked at with the scanner when the engine is running to compare to what is expected, timing, map sensor reading, injector pulse, throttle position sensor, and more.
The OBD2 vehicles have different codes, some wont even turn on the light because they are not considered emissions related.
If they exist, the scanner should
Definitely yes
Old 04-15-2008, 09:00 AM
Thanks!
Old 04-15-2008, 09:03 AM
My next question would be: Where can I pick up an OBD1 scanner for my 95?
Old 04-16-2008, 08:01 AM
http://cgi.ebay.com/ebaymotors/EZ-SC...spagenameZWDVW
This would work, I am sure actron has a few models that would work too
Old 04-16-2008, 10:34 AM
I read over the features for this item. Do you think it would allow people to make adjustments, through the computer, to the engine/transmission?
By the way, I would never do that myself. I do not know enough about it.
Old 04-16-2008, 01:09 PM
Most do not, especially the auto xray and actron. The Tech 1 and Tech 2 and some of the OTC and Snap-On may allow for some testing procedures like openning a linear EGR valve or forcing the trans into a certain gear.
I have the auto-xray 6000 scanner, there probably isn't much difference in the cheaper scanners-just don't buy one listed as a code reader if you want the other powertrain info
