Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-14-2008, 01:02 PM
89BirdMan94 89BirdMan94 is offline
Help Save MY BIRD!!! 94 firebird 3.4l
ok ok for all who have been helpin me out I recently pulled the engine out fo my 94 f-bird 3.4l cleaned it all up found a broken head bolt etc put new head gaskets etc now the reason i pulled it out in the first place is because it would overheat and i would get no heat, however after all this work its still doin it the water pump is maybe a yr old thermostat not even a month old now we jsut fired her up after puttin the engine back in and sure enough it started too overheat/not blow out ne heat however if u stick ur finger in the anti freeze in the radiator its ice cold im a a loss here ne suggestions would be appreciated thank you Also I dont see the fan kicking on even while its overheating fuses all good heres my old post everyone helped me on abotu the same subject for referance http://www.automotiveforums.com/vbul...d.php?t=764780
