Old 03-02-2003, 09:26 PM
JSPECHB JSPECHB is offline
Send a message via AIM to JSPECHB
D16Z6 Any good?
I was thinking about buying this D16Z6 from this guy. He only wants $200 for the complete motor!! Including transmission, block, head, distributor, and everything else I need just to drop it my car. Is it worth it and do the D16Z6's have potenial?
Hell, if I dont like it I can just sell it for $600 and make a $400 profit.
http://utmxracing.com
Old 03-02-2003, 09:38 PM
intrusiondetectd intrusiondetectd is offline
I'm planning on getting one myself... They have some nice potential after you put a 4th gen civic tranny and intake manifold on it it's ready to swap in.
Old 03-02-2003, 09:42 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
you wont be able to use the tranny off the z6 cause its a hydraulic tranny, you will have to use your cable tranny, my advice is to get a 89-91 Si tranny! And if he gives you a ECU, you will need to convert from obd0-obd1. Also, is your car a Si already or not? if not, you will have to get MPFI......... well, yea 200 bucks is a good price, you can probably sell the tranny for 100 bucks and you got the motor and the ecu and stuff for 100 bucks..... the ecu alone is worth 150 or so on eBay...... so good find bro!!!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 03-02-2003, 09:59 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Go for it!
Old 03-02-2003, 10:51 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Damn! is the z6 tranny a hydraulic tranny? i figured it was cable. Yea good find man, i got my complete Z6 engine, tranny, and ECU for 600. Anyone know what all it will take to switch over to a hydraulic tranny?
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-03-2003, 10:23 PM
MyFirst4G's Avatar
Do not convert to hydraulic, its so much wasted money........ the only time you'd do that is if you were putting in a Type R Tranny (B Series) or a H22 (H Series Tranny)....... if you put in a D series Hydraulic tranny on your car, i will fly over there and slap you!! but seriously, DO NOT use the Z6 tranny..... get the 88-91 Si tranny or buy my ZC tranny....
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 03-03-2003, 10:31 PM
91civicDXdude's Avatar
if you use the z6 transmission you'd have to get different mounts for it in addition to switching the clutch types
Old 03-04-2003, 08:12 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Ok, heres what I want to know. Why cant you use the Fuel injection from the 92-95 civic instead of having to convert to 88-91 EX/SI/HF MPFI.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 03-04-2003, 12:36 PM
Melt: you CAN use the 92-95 civic intake manifold except for the vacuum lines aren't routed exactly the same, you'll have to rig up a couple things. A lot of people said it cannot be done but im using 92-95 fuel injection with a non-obd pm6 ECU.
BTW, if you end up using the 92-95 manifold, and using a PM6/PG7 ECU, you *cannot* use the 92-95 fuel injectors. You'll have to get an injector resistor box and peak and hold fuel injectors from a 88-91 setup.
Old 03-04-2003, 12:48 PM
Melt's Avatar
Aight thanks for clearing that up ... something I always wondered about.
AF Bay Area Crew
Old 03-04-2003, 01:11 PM
Tony's Avatar
TLD Member #1
alright, next question, what is the difference between the DX and Si tranny?
Tony
Old 03-04-2003, 01:25 PM
GTA's Avatar
GTA GTA is offline
Whee..
the final drive. si has better acceleration...
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 03-04-2003, 01:38 PM
Mr SpiLLz Mr SpiLLz is offline
I got a 88 crx hf with a d16z6 swap, i never drove a regular crx so i cant compare =/ and i just bought this car last week. But so far it runs good, i do need to put in the ecu, and im definitly going with a 89-91 si tranny...
So can any one tell me what is the best ecu to get whats the difference between the p06 and p28 and so forth because someone is selling p28's with ocd1, and what would i need to do the obd1 conversion and what is a MPFI ? Would i need it if i went with te p28 ocd1?... Also what else other then just the tranny from the si will i need? I'll be having my uncle install everything for free, hes a mechanic i just need to bring him the parts.... So please help me Thanks alot =)
Old 03-04-2003, 02:11 PM
Tony's Avatar
TLD Member #1
Well the P06 ECU is from the 5th Gen Civic 1.5l, the P28 came from the 1.6l(Z6). For the P28(OBD1) to work you need to get a OBD0-OBd1 conversion wire harness. MPFI-Multi-point fuel injection.
that is all i thought was the difference between the 2 greg, just didn't know for sure.
Tony
Old 03-04-2003, 02:22 PM
Ok so if the ecu is for obd1 then it needs to become obd-0 with the harness to fit into a 88 rx hf, and where does the MPFI come from.. What car? Thanks alot
95 d16z6 into 91 crx si eray_92 How-To's and Walk-Through's 0 08-31-2010 04:24 PM
LSD in d16z6 transmission sohcd16beast JDM Motor & Parts info/chat 0 07-31-2010 03:10 PM
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 07:48 PM
Any good dealer with good offer for 325i in Los Angeles? oltis 3 Series 1 12-29-2003 03:50 AM
