Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-13-2008, 09:12 PM
91talondsm 91talondsm is offline
91 talon tsi no boost after findind heater hose sliced
ok well i drove the car yesterday and boosted 15psi no problem then i went out in my friends car to the club, when i got back to go home i had no boost and a loud wineing noise comming from the turbo. so today i looked around the motor and found a heater hose sliced and car had no coolent but didnt overheat. so i got a new heater hose and now the sound is louder and floored i cant get boost, it just goes up to 0psi,if im lucky i might hit 1psi. vac. is at -20 at idle.
what could it be? i checked the intake side of the turbo and the fins look fine,its not blowing smoke eather. please help thanks.
550cc's,walbro 255fp,stock 14b at 15psi,palm m130 with mmcd logging software,2 1/2in. down pipe to 3in. exhaust, high flow cat.,2g maf with k&n,custom intake,aftermarket boost guage,mbc,6 bolt with 160 compression. in closet:b16ge3 turbo,rochester 680cc inj.
wish list:wideband,headers,1000cc,e85 conversion,dsm link or map,fmic,20g,272 cams,arp head studs,2600 clutch,lsd,keydriver,. 13sec. daily driver goals.
Old 04-13-2008, 09:15 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 91 talon tsi no boost after findind heater hose sliced
Check to make sure the wastegate didn't come unhooked.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-13-2008, 09:22 PM
i did. waistgates fine, the wineing ive never herd before, i no its not normal and its hella loud.
Old 04-13-2008, 09:27 PM
im hoping its not the turbine wheel shattered.would there be obvious sighns of that?
Old 04-13-2008, 09:28 PM
Holset powered 420a
Big boost leak maybe? If the wastegate is fine and not leaking, the turbo is spinning, and you dont have a boost leak the car really has no choice but to build boost.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-13-2008, 09:35 PM
so from -20 vac. to 0psi the turbine is spinning? if so then i'l check for major boost leak but the way that turbos sounding i dont think it would be that.
Old 04-13-2008, 09:37 PM
and even if the waistgate was leaking i should get at least some boost id think.
Old 04-13-2008, 09:38 PM
Holset powered 420a
Check to make sure the turbo isin't locked up. You saying that there is a loud whinning come from the turbo, you could have a HUGE boost leak and the turbo may be overspooling. The car would run like shit when you got on it though.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-13-2008, 10:03 PM
not run like sputtering type shit but no damn power,my friends 91 four door stock accord killed my car. no top end at all(or bottem for that matter).
Old 04-13-2008, 10:06 PM
how do u check if its locked up? cause i took my intake off and spun the compressor wheel and it felt fine.
Old 04-13-2008, 10:09 PM
Holset powered 420a
Then its fine, you were just checking to make sure the shaft spun easily.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-13-2008, 10:34 PM
i just drove it and its max 2psi with a whine from hell from 0psi to 2psi. i dont no the whine is so loud, il pull the turbo off tomarrow and check the turbine wheel(exhaust side) i hope its not broke,and i'l give a heads up on what happened
Old 04-13-2008, 10:49 PM
Holset powered 420a
That sounds like a good idea. Check out the turbine wheels to make sure they aren't damaged. Let us know what you find out.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-15-2008, 03:03 PM
pulled off exhaust manifold and looked at turbine wheel(exhaust side) looked fine no oil nothin, spun freely plus shot some air into it and spun fine.so put the man. back on now its smokin white smoke and when i reved it up my friend put his hand about 2 feet from the exhaust and it burnt the crap out of him. we put a stethascope to it and the whining is still coming from right around the o2 housing where the exhaust turbine wheel is. temp guage still at normal level.
i dont no,any ideas now?
Old 04-15-2008, 03:18 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Did you check for shaft play? The wheels may be scraping on the housing sides and making that noise.
95 Talon TSI AWD
97 Eclipse GST
