| General Tools Discussions about tools - there are thousands of various tools you can use to work on your car. Do you have the right one for the job? |
Gloves
What are some good gloves for changing oil when the car is still hot?
Re: Gloves
I like Ironclad. They seem to be made a bit better than others I've used. They make a couple dozen different designs, and I'm not sure which I have. All I can tell you is they have leather fingers & palm. That is if you want something to keep the heat off your hands. If you want something to keep the oil off, neoprene gloves in addition to cloth will help with that. I usually wear neoprene under the cloth, just so they don't get torn of every sharp spot.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
Re: Gloves
check out Ansell gloves. The material is much better than leather for heat. I don't think you can buy them in stores. I get mine online: safetyprodirect.com
