Old 04-13-2008, 02:05 PM
workstar workstar is offline
yellow shift cable terminal lock
97 windstar, 3.8. I'm in the process of dropping the engine, but can't get the shift cable connector to unlock. The book says to use a small screwdriver to 'release' it until the window shows black. I've poked, prodded, and pried in the little hole and the only result is a bent jewelers screwdriver. Any advice/experience? As an alternative, if I just mark and remove the lever, but leave the TRS attached to the transaxle, will I run into problems during the engine install? TIA, ken
Old 04-13-2008, 05:45 PM
northern piper's Avatar
northern piper northern piper is offline
Re: yellow shift cable terminal lock
HI Ken
I had to remove and replace my TRS 3 months ago on a 2000. I couldn't get the yellow connector off either. I ended up just unattaching the connector at the TRS and went from there. Just for a snicker once it was off I looked at it closer and from both sides and still couldn't seem to release it. So, while I haven't been ANY help at least you know it's not a simple little clip
Piper
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 04-14-2008, 11:52 AM
Thanks Piper. That's probably what I'll end up doing. I might first try a dozen donuts at the local ford garage, though.
ken
97 F-250 XLT
97 Windstar GL
01 Focus ZX3
Old 04-14-2008, 03:19 PM
12Ounce 12Ounce is offline
I always remove the lever from the input shaft.
Old 04-14-2008, 08:56 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Everytime I tried to remove one of them, I broke it. I learned after the 4th or 5th time
