Old 04-13-2008, 12:23 PM
driftflow driftflow is offline
Whats a "cam" (DOHC, single cam, that stuff...)
Yeah so whats a cam in a car, cos after watching videos on youtube i see comments talking about single cam cars and DOHC, i learned a while ago that DOHC stands for dual overhead cam, but what is that supposed to mean? Thanks for the replies.
Old 04-13-2008, 12:41 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Whats a "cam" (DOHC, single cam, that stuff...)
Excellent, simple description of the principles and configurations:
http://auto.howstuffworks.com/camshaft1.htm
Old 04-14-2008, 02:10 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
First person to claim one is better than the other gets banned for a day.
Old 04-14-2008, 02:33 AM
UncleBob UncleBob is offline
AF -Advisor
reed valves are best *neener*
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 04-14-2008, 04:11 AM
Moppie's Avatar
Master Connector
Thats a mighty big pair of brass balls your carrying tonight Uncle.
Old 04-14-2008, 03:16 PM
J-Ri's Avatar
J-Ri J-Ri is offline
What if we say OHV is better?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-15-2008, 01:37 AM
Moppie's Avatar
Master Connector
You can get away with it, only because I know you know what your talking about
Old 04-15-2008, 04:34 AM
KiwiBacon KiwiBacon is offline
Can I vote for pushrods?
Simply so you can fit a bigger engine in a smaller place.
Old 04-15-2008, 07:01 AM
Nereth Nereth is offline
Two stroke FTW.
What will your gods do now?
Old 04-15-2008, 08:09 AM
Ok im still completely confused. But ill explain what i grasped and you tell me if im correct.
There are valves that take in air/fuel mixture, from previous knowledge i remembered that there are at least 2 valves per cylinder, intake and exhaust valve. So a cam is what makes the valves take in mixture and exhaust it. So a single cam is only 1 cam working to take in air/fuel and exhaust it. And the DOHC has 2 instead of one, and the reason 2 is makes it faster is because the faster the car goes the more air/fuel it needs, and DOHC does the job faster allowing air/fuel to be taken in a exhausted out.
Am i right?
Old 04-15-2008, 03:32 PM
Am i right?
The advantage of twin cams (DOHC) is that you can put the valves on vastly different angles, it gives a lot more freedom in how you want to shape the combustion chamber.
It can also make it easier to change intake timing without affecting exhaust or vice-versa.
Old 04-15-2008, 05:31 PM
slideways...'s Avatar
slideways... slideways... is offline
two over head cams also allows an easier and cheaper packaging route for variable valve timing and lift mechanisms. basically your statement is based on good information, but you kind of got the wrong conclusion from it. every part in a car is a comprimise. the most powerful engines also are the most complicated and expensive. thats why people still modify stone age two valve pushrod engines. because you cant get a 350+ hp DOHC 4 valve variable valve timing engine without spending easily twice as much if not much more. and sacrificing reliability to a degree. (more parts always = more broken parts at some point).
so yes as a purely theoretical measure, DOHC is better. but in reality, each engine is better for some people.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 04-16-2008, 12:13 AM
Moppie's Avatar
Master Connector
Honda would disagree.
The vast majority of their VTEC engines are single cam.
Bob, Curtis, what do you reckon, 1 day ban or not?
Old 04-16-2008, 06:12 PM
oh cmon. you know im right.
oh but i didnt mean to say dohc is better for VVT. i meant over head cam engines are better for VVT, as opposed to under head cam engines.
Old 04-17-2008, 01:00 AM
Moppie's Avatar
Master Connector
Only if you can justify it.
I would disagree with that.
I think it is simply that more and more modern engines are overhead cam, and it is the same modern engines that also have VVT systems fitted.
But they are not built as over head cam engines just so they can be fitted with VVT systems.
