Old 04-13-2008, 11:42 AM
isaiah666 isaiah666 is offline
need help w/:idoling,timing,and gas
94 s-10 chervy blazer 4x4 4.3 liter vortex cpi
well, my dad works on my car and i try to help when possible. he saids that it idles rough and the motor shakes but once you start to drive it it runs smooth. were trying to adjust the timing but it seems like we're missing all the time. when im driving the car, it seems like it burns a lot of gas and its just from driving around town. half the tank would be gone but the end of the day. so the questions are
how do we stop it from idoling badly?
how do we get the timing perfect or at least near it?
and is it supposed to burn so much gas?
Old 04-13-2008, 11:51 AM
jimgunthorpe's Avatar
jimgunthorpe jimgunthorpe is offline
Re: need help w/:idoling,timing,and gas
hey there, theres guys on here who are much more knowladgable than me but have you tried Cleaning you fuel injectors? Changing the fuel filter? also when is the last time it got new plugs, plug wires, rotar/distributar?
-Jim
2000 (4X4) 4.3 Vortec Chevy Blazer LS
Old 04-13-2008, 01:17 PM
yea, we replaced the plugs,wires,and rotor/distributar. we changed the fuel filter also. the fuel injector, tried it once but the thing is that the gas has been sitting in there for 2 years and a half. we changed the fuel pump though since it was clogging it.
Old 04-13-2008, 04:49 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
To set timing you need to put it in base time mode.
Disconnect the single wire tan /black under ac/heater box inside cab sometime hid under capret or under glove box.
MT
MT
Old 04-14-2008, 05:01 PM
MT
how exactly would you do that. i thought the timing was on top of the car. thats where/how he know how to change the timing for it. also, he doesnt know what the base time mode is =/
Old 04-14-2008, 05:28 PM
MT-2500's Avatar
AF - Advisor
To set the timing you need to learn how to put it in base time mode.
Disconnect the base time bypass wire as directed.
Find a good repair manual and read up on the procedure and proper way to do it.
Good luck
MT
MT
Old 04-14-2008, 05:36 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
MT
Do just as MT instructed. After disconnecting the the tan/black wire, you then go ahead and adjust the time using a timing gun and rotate the distributor untill you set your timing mark at zero degrees. Once you set that tighten the distributor hold screw then recheck your timing to ensure that its still zero and it didn't move while you where tighten down the bolt. After that, go ahead and reconnect the tan/black wire. You'll need to clear your error code either with a scanner or by disconnecting the pos side of your battery for a min. After clearing you code start your motor. Your base line timing should be set. Use your timing gun and check your timing. It should be reading at 20 Advance.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
