Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Classifieds
Old 04-13-2008, 11:39 AM   #1
ned032002
ned032002's Avatar
WTB: BISS made out of anything other than plastic
As the title says, I'm looking for a BISS that is not made of plastic. I've purchased a BISS from both Extremepsi and JNZ tuning and they were both made out of plastic. When I try to install them they start to break off and so I then need to drill a hole and sink a screw into them and pull them out in order to get them back out. I want to fix this problem for good. So if anyone has a BISS in good shape that's not made out of plastic that you want to get rid of, let me know.
ned032002 is offline   Reply With Quote
Old 04-13-2008, 02:12 PM   #2
steviek
steviek's Avatar
Re: WTB: BISS made out of anything other than plastic
is it possible for you to just take your plastic screw and go down to the hardware store and try and match the size and thread pattern??
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
steviek is offline   Reply With Quote
Old 04-13-2008, 03:39 PM   #3
rock0134
Send a message via AIM to rock0134 Send a message via Yahoo to rock0134
What is a BISS
SOLD
'97 GSX
EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels
'05 blacked out f150 FX4
rock0134 is offline   Reply With Quote
Old 04-13-2008, 03:45 PM   #4
steviek
steviek's Avatar
Base Idle screw basically if you turn it up rpms go up down rpms at idle go down. Its right on the throttle body. It tends to leak boost pressure at lot.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 04-13-2008, 04:12 PM   #5
rock0134
Ahh i see... or if you have link you can use that!
SOLD
'97 GSX
Old 04-13-2008, 06:07 PM   #6
ned032002
ned032002's Avatar
This is what it looks like
http://www.extremepsi.com/store/cust...cat=971&page=1
If I were to go to the hardware store and get a bolt from them, where would i put the O-ring on the bolt?
Old 04-13-2008, 06:20 PM   #7
SilvrEclipse
Holset powered 420a
SilvrEclipse's Avatar
Send a message via AIM to SilvrEclipse
Just use some teflon tape on the threads.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
SilvrEclipse is offline   Reply With Quote
Old 04-13-2008, 06:22 PM   #8
ned032002
ned032002's Avatar
Has anybody ever done that? The main reason that I want to get this fixed is because when the cars cold I'm idling at 3000rpms and when it finally warms up she comes down to about 2200rpms at operating temp. I'm sure that I am getting horrible gas mileage due to this because every time I stop the idle is mad high as if I were moving along. Not to mention it's not good for an engine for when it first starts in the morning to start up at 3k.
Old 04-13-2008, 08:26 PM   #9
SilvrEclipse
Holset powered 420a
What does the BISS do? I know it adjust the idle but what exactly does it control? Is it just like a valve that lets air in kinda like the IAC.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-13-2008, 10:19 PM   #10
EDMUND65
EDMUND65's Avatar
Send a message via AIM to EDMUND65
my gsx idled like that... want to know how i fixed it? ahah
I sold it... and that kid blew it up!
EDMUND65 is offline   Reply With Quote
Old 04-13-2008, 11:42 PM   #11
ned032002
ned032002's Avatar
The further it's screwed in, the less air can get through. If I can't screw it in any further without chipping plastic off then I'm going to keep idling high so I need to fix this.
Old 04-13-2008, 11:56 PM   #12
SilvrEclipse
Holset powered 420a
So it basically just allows air to bypass the TB plate? Why would you even need the BISS screw? The IAC motor should adjust the air for the idle, what would happen if you just cut off all the air going throught that part?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-14-2008, 07:05 AM   #13
ned032002
ned032002's Avatar
I would assume that the idle would die out, but I'm not sure.
Old 04-14-2008, 10:22 PM   #14
EDMUND65
EDMUND65's Avatar
so stick your finger over the hole and have someone crank it
Old 04-14-2008, 11:24 PM   #15
tfoti
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
NED: I have a N/T throttle body just sitting here. I'm sure it has the metal BISS. I only live about 45 minutes from ya...
Like said it's the BASE idle set screw. The IAC adjusts at idle when accessories are turned on such as the A/C
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
tfoti is offline   Reply With Quote
