Old 04-13-2008, 09:53 AM
edgograbow edgograbow is offline
91 stealth trans problem
I have a 91 dodge stealth fwd automatic> When i shift from park to drive or reverse, it lunges or jumps into gear. Other day i shifted from park to reverse and got nothing. Eventually it engaged into reverse after a few minutes. Also, the power/economy rocker switch next to shifter is stuck. Any suggestions?
Old 04-13-2008, 10:59 AM
Hotshot8792 Hotshot8792 is offline
Re: 91 stealth trans problem
May want to look at the shifter linkage connection under your air intake pipe in your engine bay. Thats where the arm that connects to the lever you pull to put it into drive, to the transmission. Then you may want to consider changing your transmission fluid and filter. Sometimes that fixes some of the minor transmission problems.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
