Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 04-13-2008, 01:07 AM
mikejennyw mikejennyw is offline
running hot
my 1989 firebird gets hot. it runs at about 200-210 i would like it to run at 170-185 i have replaced radiator, water pump, thermostat, cap, checked timing, replaced head and intake gaskets, so what is wrong can someone help me? also this car was wrecked in the front end when i bought it so have also installed an air scoop under neath the car. however i have not seen another one to compare in to so i do not know what is missing please tell me
Old 04-13-2008, 02:21 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: running hot
200-210 is OPTIMAL OPERATING TEMPERATURE.
You don't want it running cooler - this reduces your economy and messes with the operation of the computer. It also increases emissions - if you're running 200-210 you're running in the sweet spot.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-13-2008, 02:38 AM
Re: running hot
if your driving down the highway it runs about that but if you are in town it gets up to 230-220 i also have a clutch fan on it because the electric did not even try to keep it cool and i had it checked out and it is fine what do you think i think i am missing some sort of shroud or air dam
p.s. thanks for your quick reply
Old 04-13-2008, 02:43 AM
Re: running hot
well when your driving down the highway is stays cool but when you are is stop and go traffic it gets to 220-230 wich is a little high for my comfort i also have a clutch fan on it couse the electric was not cooling it i had it checked out and it was fine so i think i am missing some shroud or air dam
Old 04-13-2008, 09:31 AM
777stickman 777stickman is offline
Re: running hot
The fan shroud would make all the difference in the world when driving around town. Go to a salvage yard and get one for your '89.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 04-13-2008, 10:56 PM
Re: running hot
problem solved there is a plastic scoop thing that goes from the radiator uper support to the bottom of the bumper is was missing i put it on and the electric fan back on and it stayes nice and cool
thanx everyone
Old 04-13-2008, 11:09 PM
Re: running hot
on my 1989 chevy full size blazer it has a 350 tbi last sommer it sprung a head leak i replaced the top end gaskets and had the heads done but now it will not idle i have put a new throttle body on it and the compresion is at 125 per cilender give or take one or two pounds. i have checked the timing changed plugs wires rottor cap. and still nothing it also seems to have lost power alittle but i could be mistaken. i pull a sixteen foot enclosed trailer everyday with it and it seems to run ok but just will not idle Help
Old 04-14-2008, 01:55 AM
silicon212's Avatar
Confoundingly Lucid
Re: running hot
Please start a new thread for maximum exposure.
Old 04-14-2008, 09:39 PM
Re: running hot
sorry to bug you but how exactly do i start a new thread i am not comp freindly thanx
Old 04-15-2008, 12:45 AM
silicon212's Avatar
Confoundingly Lucid
Re: running hot
That's fine - when you get to the main page for this forum, you should see a button that says "Start new topic". That will get you going.
