Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Interiors
Old 04-12-2008, 09:54 PM
jeremytalon92's Avatar
jeremytalon92 jeremytalon92 is offline
Exclamation flicker of lights
every time i push the brakes or have the radio loud the head unit and the dome light flicker.btw!i changed the battery and alternator already!
kosei black powdercoated 16'' rims,hyoshi muffler,removed smaller honeycomb in maf,ngk wires and plugs,luk clutch and pressure plate,stock flywheel,traction t/a bfgoodrich tires,silverstar ultra headlights
Old 04-13-2008, 10:28 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: flicker of lights
Do you have a sub in the car? I would hook up a volt meter to the battery while the car is running and see how much voltage you are getting. Then push the brakes or turn the radio up loud to make the lights flicker and see if the voltage drops a lot.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-14-2008, 10:21 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
I think your stepping on a wire. Not physically, but the pedal sliding back and forth under the dash.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
