Old 04-12-2008, 08:03 PM
donk2644 donk2644 is offline
Inside IBM or Relay/fuse Box
I opened up today the old relay/fuse box form my 02 caravan to see why it was not letting my blower motor run.
The protective coating on the inside circut board was peeling an lifted with corrosion on the printed circut board. The clear material was flaking like rust but it was clear and a silicon type material
Just another crappy piece of stuff built by Dodge/Chrysler.
If mine went after 6 years many others will be going.
Old 04-13-2008, 02:31 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Inside IBM or Relay/fuse Box
Yup, IPM corrosion issues have been popping up on the forum more often lately. Apparantly it's not sealed well. Has anyone found a better way to seal it?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 04-13-2008, 06:33 AM
I don't think you can seal it, the circut board is in a plastic box, sort of water tight but not good enough to sit under the hood in the side front of the engine compartment, Just a lousy design from Dodge.
Mine started acting up after the last snow sorm we had here,(toronto) wind with snow blows into any crack or crevis, probably filled with snow, melted then shorted rusted out.
Don K
