Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-12-2008, 04:09 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
how to change blinker lights on dash?
Since i got my car about 6 months ago the blinker lights have never worked. After taking apart the whole speedo dash thing i found out that i think theres this plastic piece under the steering column you have to take out so you can access the light bulbs from the back i think? Only problem is that the piece of crap chapman lock (which is a scam and doesnt work anymore) is bolted right over that plastic piece i have to remove. How convenient! But anyway i managed to take one bulb out from the front and connected it to a battery. It does work. So now what should i be looking for? I don't think there'd be a separate fuse for just these blinker lights (and the highbeam light) or would there be? I was able to bend lie down on my back to look behind the dash and i got a slight glimpse of the metal piece the blue blinker thing comes in contact with and if i'm not mistake it looked all rusty. I have no clue how to get to that thing.
Took out a big screwdriver to take off the chapman lock and the bolt chipped! None of my wrenches fit it either cuz its metric or soemthing. I'll get it off somehow...
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 04-12-2008, 05:59 PM
mike561 mike561 is offline
Re: how to change blinker lights on dash?
I know you have the same guage cluster as me, (the four round seprate ones) i've had mine off a few times, you may not need to remove that little blue socket, after studying how it is, you may be able to just pull the bulb out from the front with long nose pliers, but i've never tried that. since we're on the topic of blinker bulbs too, quick question: does anyone know if the boxy caprices had the feature that makes the blinkers flash quicker if a bulb is out or is that only on newer cars? (diddnt mean to hijack your thread)
2006 Chevy Cobalt LS
Old 04-13-2008, 02:09 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I have large hands and so I don't like to try to remove them from the back. If one burns out anywhere in the cluster, I will remove the cluster from the front and then it's easy access. I replace all of them if one burns out.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-13-2008, 11:38 AM
bhw33191's Avatar
So does this mean that if one goes out, then they all wont work (like on some christmas tree lights)? Hopefully thats the case.
Old 04-13-2008, 12:03 PM
silicon212's Avatar
Confoundingly Lucid
No, nothing like that at all. It's just if one bulb burns out, they're all getting close on the age thing and I will do them all - to save myself from having to do this for another 10 years or so.
Old 04-13-2008, 12:09 PM
makes sense, when i first got my car, someone removed the check engine bulb, which i thought was strange, i put another one in and it only comes on when the key is first turned like it shoul normally.
