Old 04-12-2008, 03:11 PM
MooseNelson's Avatar
MooseNelson MooseNelson is offline
Timing WAY advanced, Runs Again!
Hi there, I posted back a silly thread about having adjusted valve clearance on my rocker arm cam 1992 eagle summit (mitsu 1.5).
So after changing the plugs under heavy throttle, this sickening stutter, like serious backfiring, almost dangerous inability to accelerate.
So today I messed around and finally got the courage to advance the timing by unlocking the distributor and rotating it. moving towards advanced, idle goes way up and under heavy throttle pressure, WAM, straight up the RPMs, no stutter.
SO:
Bought a timing light to look at what is going on. CAM notches line up when crank mark is lined up, so don't think i jumped a tooth.
But this thing stutters like Ron Jeremy when timed to marks (nice little $10 inductive shooter), I have to advance the distro almost all the way, to achieve any unflattened accelerate pressure.
WHY? Is the advance timing compensating for crappy spark?
http://www.georides.com
Sub Compacts, Electrics, Biodiesel, hydrogen
Old 04-12-2008, 05:17 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Timing WAY advanced, Runs Again!
It is possible the auto advance has seized in the dizzy.
Old 04-12-2008, 07:32 PM
UncleBob UncleBob is offline
AF -Advisor
what moppie is referring to, the mechanical mechanism in the distributor that applies advance is a simple weights and spring setup, as the distributor spins, the weights get flung out and overcome the springs at a set RPM
If that assembly is seized, it won't advance as teh RPM's increase
Simply put the timing light on it and rev it up with vacuum hoses disconnected (if any). You should see a 20 or so degree increase from idle, by 2500-3000 RPM's or so. If it doesn't move at all, it needs a distributor, or you need to rebuild the one you have.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
