Old 04-12-2008, 12:28 PM
nank6 nank6 is offline
96 cavalier brakes - HELP
How do you remove the brake piston from a left rear brake drums?
Old 04-12-2008, 02:24 PM
inafogg inafogg is offline
Re: 96 cavalier brakes - HELP
HELLO NANK,not sure what you want to do???if brakes are drum brakes what piston are you talking about!!more info please as to what you are trying to do.....
Old 04-12-2008, 03:59 PM
muff34 muff34 is offline
just guessing that you want to remove the brake/wheel cylinder? . remove the brake shoes. remove brake line from cylinder .Two bolts go thru the backing plate into cylinder remove those, likely to twist off .then pry the cylinder out. Hopefully backing plate is still in good shape. And Welcome to AF
Life Is A Highway ,Enjoy The Ride
