1994 SL1 transmission fluid leak
when i first purchased the car it was leaking just a little bit............ I guess I got comfortable for a while and did not add trans fluid for a while. So as i was on my way home from school the trans began reving and shifting out of wack. So i pull over to the local gas station and adding some trans fluid but it was leaking straight out as i was pouring it in.... I check the pan gasket and it was fine...........Now i am lost................Where else is a common place to locate trans leaks............ It look like its coming from the back right in of the trans........................
Re: 1994 SL1 transmission fluid leak
Blown differential pin for a leak that bad. You need a new transmission
it was my transaxle seal on the passendger seal...............
Lucky
