Old 04-12-2008, 11:47 AM
shyguy151 shyguy151 is offline
3000gt won't start
ok so this topic angers me a little as people don't seem to listen to the main points here. they see "won't start" and automatically say its the starter so heres the rundown.
I recently got back from Iraq, while away the battery obviously died. So I replaced the battery and now the 4 ways come on for about 20-30 seconds then go off. The radio is coded out. The car CANNOT BE PUSH STARTED. And when you turn the key in the ignition you can hear it make contact. Does anybody have any ideas about this. I am assuming the anti-theft device but that is a never ending battle. Is that something that I can remove? If so how?
Old 04-12-2008, 01:24 PM
new2mitsu new2mitsu is offline
Re: 3000gt won't start
so the car wont turn over at all, correct? is it atx or mtx?
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 04-12-2008, 01:26 PM
if by mtx you manual trans yes it is.. other wise i've never heard of that i'm new to the 3000gt
and no it won't turn over at all. it doesn't even try
Old 04-12-2008, 01:29 PM
when you try, does it click when you turn the key?
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 04-12-2008, 01:44 PM
yes you can hear a click in the steering column
Old 04-12-2008, 01:48 PM
ok, this is a long shot, but turn your key, and kinda stomp your clutch pedal. i had a similar problem, and it was due to the switch in the pedal goin out, so to get it to work, i had to hit it really hard. I think there is a way to bypass the pedal, but i cant remember how to do it. Do all your other in car electronics work correctly(like ur radio n stuff)?
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 04-12-2008, 01:51 PM
well the radio doesn't work but that is becuase i don't have the code for it but yes everything else works. i can try the clutch pedal but i have been pushing pretty hard on it. I bought this car from my buddy and he said there was a step by step process you had to follow after changing the battery to deactivate the ignition cut off.... if you or anybody you know, knows how to bypass that I would be very appreciative
Old 04-12-2008, 02:09 PM
thats odd, what year is ur car? i have a 93, and ive had my battery in and out hundereds of times. never had any ignition cutoff. Wish i could be of more help. sorry.
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 04-12-2008, 02:12 PM
ok, so i justtalked to my buddy about it, he said they were overridin it by "jumping' the starter, which from my understanding involve either bridgind the wires on the foot switch, or running a lead or jumper cable from the battery straight to the starter
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 04-12-2008, 02:14 PM
yeah i don't know its a 94' and I just don't know who to ask anymore I am pretty good mechanically I just not with electronics and thats the only thing I can think of at this point
Old 04-12-2008, 03:35 PM
alright update! I just hooked the horn up for the alarm; and this is strange. the alarm will go off for 30 seconds then shut off. but when I try to start the car it starts going off again
Old 04-12-2008, 03:48 PM
do you have a keypad for the alarm?
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 04-12-2008, 03:50 PM
no i dont' there is a little black box by the fuse panel that has a white knob on the side and a red light that blinks when you bump it. Also there is a yellow light to the bottom left of the fuse panel that comes on.
Old 04-12-2008, 04:28 PM
Sunni Sunni is offline
i know in my stealth they took out the a/s in it so it possible yes but how to do i have no idea i would think the a/s box is right next to the fuse panel under the dash but dont quote me on that if im right you should just be able to take the box out and it will work but if im wrong no harm in trying right
