Old 03-02-2003, 05:52 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Big Problem - Stumped!!!
I just swapped my old D16A6 motor for another D16A6 motor that supposedly doens't burn oil. We just got the swap done, got everything hooked up, and tried starting it - nothing. The engine turns over, but doesn't ignite. I'm getting spark - I checked all the spark plug wires, and I put my old spark plugs in just to see if I would get anything different. No change. I can smell gas after I crank on it for a minute or two, so I'm getting gas. I'm completely stumped. No error codes, nothing. Any ideas anybody.
Nick
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 03-02-2003, 06:04 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
whoa man, thats got me hella stumped! ur getting fuel, and spark, which is good, and ur prolly gettin air too so thats good so it should fire right up, the plug wires going to the distributor might be mixed up but i doubt it cuz i had my car running on 2 cylinders by accident and that was my prob but it fired up, umm, check all connections again, double check battery, and check the wires to the distributor, there might be a loose connection there, i dunno, i hope u get it sorted out tho,
Old 03-02-2003, 06:15 PM
4G4D Store's Avatar
We double checked the firing order and stuff like that with the spark plug wires, and they're correct. The only thing I can think of is timing belt is a tooth off, or is't flooded.
Nick
Old 03-02-2003, 06:17 PM
1PhatCX's Avatar
if ur timing belts off, u would heard a bang when u first started ur car prolly, the ppl who did my head told me to have it EXACT unless i feel like gettin bent valves haha, yea it may be flooded, in that case, try, try again haha. good luck tho dude
Old 03-02-2003, 08:22 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
Check all your ground wires...I had a ground off right behind the head and it was doing exactly what yours is. Find all the grounding points on the engine and make sure their hooked up.
Old 03-02-2003, 08:58 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
another quick fix to this is take some jumper cables and connect one to the negative on your chasis and the other end on your engine....... and see if that works..........
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 03-02-2003, 08:59 PM
MyFirst4G's Avatar
That is if its a power issue
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 03-02-2003, 09:12 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
I'm going with you don't have all your ground straps on.
Old 03-03-2003, 10:19 AM
redmanjd redmanjd is offline
try swapping dist. maybe crank sensor is bad.
Old 03-03-2003, 01:44 PM
4G4D Store's Avatar
Well, we got it started - finally - I guess a couple of the spark plug wires were in the wrong position and the piston rings were dry with no oil, so we weren't getting any compression. I think there was something else, but i can't remember what he said. So anyway it's running. Kinda smoking but that's understandable right now. I'll keep you all updated.
Nick
Old 03-03-2003, 03:45 PM
1PhatCX's Avatar
whoa, didnt i say sparkplug wires? lol, yea i did that too but my car fired up when i tried but it was horrible trying to start. sounded really sick but its all good now,
BIG BIG problem with my Rodeo skw5s Rodeo | Passport | MU 10 09-06-2005 01:35 PM
I GOT MY CAR BACK. Big difference but also I got a big problem. Savior1974 Off-Topic 17 12-13-2004 11:47 AM
Big Big Problems Help Please! Leckster Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 9 11-12-2004 10:46 PM
help big big problem man4ou Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 08-12-2004 09:48 PM
Big, big problem. HEEELP PLS qpiec Off-Topic 14 01-23-2004 12:37 PM
