Old 03-02-2003, 04:41 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Oil Pressure.
Can anyone with a oil pressure gauge tell me how much the pressure fluctuates?
I have seen mine rise as far up as 90psi. Is that normal?
Old 03-02-2003, 06:16 PM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
Re: Oil Pressure.
When my car is cold mine is way high, like 90+. Once it warms up, during idol it's kind of low like 20. while driving normally it will be around 60.
Mike
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
My dads 98 Silverado has a stock oil pressure gauge, and when he hits the gas it will go from 40 to about 80 and then stay constant around 60 while he is driving.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 03-03-2003, 12:11 PM
kris's Avatar
Re: Re: Oil Pressure.
Mike
Cool. I just saw 90 and was like, wow.
Old 03-03-2003, 07:02 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
how do you install oil pressure gauges anyway? I heard you need to tap into the block or screw something in? I will be buying one soon.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 03-03-2003, 07:41 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
It depends. If you buy a mechanical gauge you do need to tap into the oil system somewhere, and run a tube to the gauge. If you buy a electric gauge you splice into or replace the oil pressure sending unit, hook up a few wires and your all set. Either way follow those manufacturer instructions. Later....
Old 03-03-2003, 07:47 PM
intrusiondetectd intrusiondetectd is offline
I've got a mechanical gage from a former project, how and where would I install it on the d15?
Old 03-03-2003, 08:25 PM
so oil goes from your engine to the gauge on mechanical ones? that sounds pretty freaky, i wouldnt trust on of those heheee!
-2000 Civic Hatch
-1998 Lexus SC300
Old 03-03-2003, 08:36 PM
believe me (exp. talkin) if you dont use the plumbers tape on the threads YOU'LL REGRET IT!!!!!
my 83 bonneville had a permanent oil stain in the carpet after a mishap with the first one I installed.
Old 03-03-2003, 09:38 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
installing a oil PSI guage is a pain in the but. I have an electrical one. Granted i installed it wehn i was swaping in my ZC so it was cake. But for those who have ther engine in your car...... you have to replace the stock oil sending unit wit the one that comes with hte guage. And in my case the new sending unit was to big for the stock location so i had to buy some extending tubing/piping. but all in all it works good. YES definatly use teflon tape (plumbing tape) or else oil will be leaking.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 03-04-2003, 04:50 AM
trav, that's why I've decided to put on on the D15... it's not currently in the EX
Old 03-04-2003, 08:58 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Yo...I used Endyne's idea for mine... http://www.theoldone.com/articles/oilpressure/
I haven't completed it yet...but I have all the parts, and I have the part in the block...this would still work if you have a mechanical gauge...I would just recommend running a line to a "T" fitting mounted on the firewall..here is the fitting on my ZC (which has the same fitting as a d15) which I bought as a kit + a few misc. parts from my local Napa for about $12.
It is prolly pretty hard to see with all kinds of other shit in the way...if you have the car up on jackstands, and remove the oil filter, you should be able to see the location on the block. I of course have taken this while the ZC is on the engien stand
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 03-05-2003, 02:18 PM
kris's Avatar
That is exactly what I did. It works great.
Old 03-05-2003, 02:19 PM
kris's Avatar
No, not unless you are hitting like 500 psi.
There will be compressed air between the oil, and the actual gauge. The oil in the tube does not even heat up enough to feel warmth through the line.
Old 03-05-2003, 08:50 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
When I first innstalled mine it leaked at the gauge so it has a little oil in the line...oooops
'98 Regal.... no oil pressure after changed oil Mr_D Regal 6 04-06-2010 12:08 AM
Oil pressure gauge roknjock2 Chevrolet Classics 11 07-30-2009 08:33 AM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 05:52 PM
No oil pressure on my big block 454BLAZER Problem Diagnosis 10 05-22-2009 12:37 AM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 07:27 PM
