400 Heads on a 350?
Working on a friends SBC motor. Here's my research:
Block casting # 3970010 Date code D248 Pad stamp suffix is CLR Research shows it's a 1978 350 2 bolt. Original heads had some cracks. He came up with some 400 SBC heads. Casting # 3951598 76cc 1.94 IN/1.50 EX Date code C11 & C3 70. 1970 400 heads. I know that there are cooling passage differences in the 350's & 400's. So the ? is will these 400 heads work on the 350 block? And should I use 350 head gaskets? Steve
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
Re: 400 Heads on a 350?
as long as you arentputting non-400 heads on a 400 you will have no problem
only the 400 heads have the extra holes others do not no issue here good luck
I also am user fastr68 here- Randy -'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee, |
Correct - the steam holes present on the 400 heads are the only difference. Most 76cc head castings made in the 70s were used interchangeably on either 350 or 400 engines from the factory. If you do ever want to run 350 heads on a 400 however, you will need to have the steam holes drilled into it.
No big deal if steam holes are present on a 350- the head gasket will seal them.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Thanks you both..............Steve
