Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-11-2008, 06:19 PM
eclipse787 eclipse787 is offline
longer rods for eclipse
i bought some eagel rods for my 420a motor. the wrist pin fits and it bolts to the crank, but its too long. the guy i bought them from on ebay said they were for a 420a but i looked at eagels website and there .136 incehs long. do i need new rods or modifications to the head?
Old 04-11-2008, 07:00 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: longer rods for eclipse
If the rods are to long you will have to buy new ones. Do you have a stock rod you can compare the length to? Messure how long the rod is total with a ruler. I have a set for the 420a so we can see how much longer yours are. You need to find out what they fit.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-11-2008, 10:08 PM
well heres the part number from eagle crs5608n3d. there .136 longer. why would they make a longer rod if it wont work in a motor?
Old 04-12-2008, 02:54 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
You just bought the wrong rods, the ones you need are CRS5472N3D. Next time you might want to read the auction before you jump into something like that, that was a pretty costly mistake due to haste. It will work if you get a crank with a shorter stroke, but I think cranks like that are generally a good $750-$1500 depending on brand and availability and such.
A "long rod" setup is used in destroking motors so that the piston will still come up to the right height. This is used to get a better rod ratio (length of the rod over the stroke) which helps in rev happiness of the motor. Ever wonder why its generally said you cant rev out a stroker? This is why.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-12-2008, 12:59 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
I hit 8000 today...Not used to the light flywheel yet.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 04-13-2008, 08:53 PM
Thanks guys. looks like im buying different rods. its way to hard to find a crank with a shorter stoke, and who knows how much it would cost. although higer rpms do sound appealing. since the auction on ebay said they were for a 420a eclipse, im getting my money back. mabye next time he'll do a better job in describing them!
Old 04-16-2008, 01:08 AM
can anybody help me find a shorter crank shaft? i dont know if i am going to be able to get a refund on these rods. it might be easier to just get the smaller crank. thanks
Old 04-16-2008, 01:18 AM
Thor06's Avatar
Jizzed In My Pants
On a 420a, I doubt you'll be able to find one... and if you do its going to be probably around a grand minimum. Its definately going to be cheaper to just buy new rods and relist those bad boys on ebay.
Old 04-16-2008, 01:22 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I've never seen nor heard of a destroked 420a. Chances are, you'd have to get a custom crank cut, which could cost a couple grand at minimum. Turn around and sell the rods, and then buy the right ones.
95 Talon TSI AWD
97 Eclipse GST
Old 04-16-2008, 01:27 AM
well what i was hoping for was a stock crank and maybe the neons came with two different cranks. that way i could just buy a stock one thats shorter. but i guess these shorter stroke cranks are one of a kind.
Old 04-16-2008, 09:22 AM
Holset powered 420a
Yea no other cars use the one that you will need. You should be able to get your money back no problem though if you payed with paypal.
98 Eclipse GS Turbo
2001 BMW 325i - DD
