Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 04-11-2008, 03:15 PM
jveik jveik is offline
cylinder head bolts
i am wondering if any of the cylinder head bolt holes in the block for small block chevys protrude into water jackets.
Old 04-11-2008, 03:21 PM
maxwedge maxwedge is offline
A990 racer
Re: cylinder head bolts
If you look down into the hole you can see where they end, if the bottom is open they are usually in a water jacket.
Old 04-11-2008, 05:07 PM
luxeryvic luxeryvic is offline
yeah, they do
Old 04-13-2008, 01:01 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
they do
and use a non hardening lube sealer such as plumbing pipe thread sealant on the threads and engine oil on the head seats
and chase clean the bolt hole threads
so they will torque properly
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 04-13-2008, 02:15 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
If I use sealant (which I generally don't), it's Permatex #2 Form-a-Gasket. It's what the factory used.
I personally feel that sealant will give you a bogus number on your torque wrench and the incidence of leakage due to no sealant is almost nonexistant.
Case in point is the 350 in the car in my sig. This engine now has 300k miles on it since I rebuilt it in the summer of '93, and I had the passenger head off a month ago to replace a bent valve. Inspection of the bolts revealed no leakage or corrosion.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-13-2008, 08:46 AM
A990 racer
Areed an the sealant/torque issue, I use some lite non -hardening thread sealer and add about 5 lb/ft to the torque settings.
Old 04-13-2008, 10:32 PM
so basically, if i wanted to be on the safe side, i could use some sealant and just up the anty on the torque wrench a little bit. or i could just as well not use sealant at all and more than likely nothing bad would happen?
Old 04-14-2008, 09:10 AM
A990 racer
Your call.
Old 04-15-2008, 08:46 AM
MrPbody MrPbody is offline
AF -Advisor
DANGER WILL ROBINSON!!!
Absolutely use a sealant. Permatex "Aviation" or "Super 300" are the two of choice. You MUST use some sort of lubricant on the bolts to get an accurate torque reading. Both of these sealants provide a similar result as motor oil, which is used on engines with "blind" holes. ALL the head bolts go through to water in a factory production small block (and big block, for that matter).
I too, have seen engines without sealant that didn't leak through. But I've seen 100 that did for every one that didn't. Chevrolet says to use a sealant. When all else fails, follow intructions! Chevy used #2 in olden times. They used Teflon (Slick-Tight) the last 20 or so years of production.
Sorry to sound like a smart-ass, but this is an important issue regarding the longevity of a Chevy engine, and witch-doctor cures and home remedies don't make it. Do it right, do it once!
Jim
Old 04-19-2008, 01:00 PM
how do the sealants change the torque reading? Well, i know "how" they do it but i mean do they make the required torque reading on the wrench go up or go down to get the correct torque? i was going to just use motor oil or petroleum jelly, but i think i might opt for one of the sealants you listed above. are both of these sealants ok for aluminum heads, i have no idea if there are products out there that will be fine for iron but eat away at aluminum
Old 04-19-2008, 01:42 PM
Will Help Will Help is offline
This design is one little thought of reason why GM and other manufacturers have trouble with blown head gaskets.
Not having head bolt bosses that go all the way down to the lower crankcase allows the head decks to flex as they heat and cool. This flexing/bulging, combined with the pressures of combustion, breaks the gasket bond over a period of time. Kind of like putting hot water in a milk bottle and putting the lid on. The bottle will start to bulge as pressure increases. Put the same bottle in cold water and it will pull its flat surfaces in. Having the bolts go all the way to the bottom end stabilizes the head deck and keeps flexing down to a minimum.
Also little known problem is aluminum heads on cast iron blocks. Aluminum expands and contracts almost twice as far as cast iron when it heats and cools. This also breaks the gasket bonds faster.
Old 04-21-2008, 07:26 AM
Blue Bowtie's Avatar
Registered Offender
I've got a pretty good handful of SBCs, and I don't have any problems with head gasket failure. I've replaced quite a few on other engines, but the five bolt design of the old SBCs made it one of the strongest head/deck joints of all the major manufacturers.
If you want good sealing and no torque errors, try one of these:
Old 04-28-2008, 12:59 PM
AF -Advisor
The types listed by Blue Bowtie are just fine. We use Permatex Aviation becasue we use it for several other sealant applications as well. We have no head gasket issues, either. The "torque issue" is more a "dry" hole vs. a "lubed" hole.
The "open" holes to water are pretty much exclusive to Chevys in the GM line. Buick, Olds and Pontiac V8s have "blind" holes and separate bosses. Even though they only have 10 bolts, they suffer fewer gasket problems than the Chevys.
Small Fords have open holes in some blocks, blind in others. The big Fords are blind holes. Again, 10 bolts, few problems. Big Dodges have 17 bolts like the SBC, and they're open. We've seen SOME problems, but not like the SBCs. The small Dodges have 10 blind holes.
NOTE: Most of the "blind hole" types have larger diameter bolts, too (1/2" vs. 7/16"). The Lima (385 Series) Fords (429/460) have 9/16" bolts.
Just for clarity.
Jim
