Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 04-11-2008, 03:02 PM
axslinger2004 axslinger2004 is offline
88 t-bird 3.8 v6 flooding
I have a problem w/my 3.8 v6 t-bird. when I try to start the motor it runs for about 15 seconds and then fouls the plugs.I already replaced the fuel pump, the temp sensor, and the brain. I need to find out what other system issues would cause the fuel injectors to run rich
Old 09-05-2008, 10:44 PM
K5Calamity's Avatar
K5Calamity K5Calamity is offline
Re: 88 t-bird 3.8 v6 flooding
This is just totally armchair troubleshooting here, but have you tried new O2 sensors?
Old 09-06-2008, 11:54 PM
fasthauler fasthauler is offline
I have never heard of anything that could cause the plugs to foul out in 15 seconds. Are you sure the spark is hot enough to adequately fire the plugs? Also make sure the fuel return line is not blocked. This is something that is often overlooked. The MAP sensor, ACT sensor, and the ECT sensors could all be causing the problems as well as the OXY sensors. You can test these sensors with a good ohm and voltmeter. If it is a bad sensor the voltage or resistive measurements are going to be obvious if the thing is fouling out plugs that quick.
Gary 1986 T-Bird 3.8L V6, 1977 F250 460 Hauler
Old 09-07-2008, 07:07 AM
rhandwor rhandwor is offline
I would check the fuel pressure. A tester looks like this.
http://www.autopart.com/tools/toolsmain/tool/T_3440.htm
If it is high check for a bad pressure regulator or plugged return. The pressure regulator should be on the fuel rail. Pull the vacuum tube if leaking replace it as this pulls fuel into the intake. You can also buy cleaner for the air flow meter and clean it. Make sure the air filter is clean and don't have an obstructed intake.
