Old 04-11-2008, 12:52 PM
PeterLech PeterLech is offline
Won't start - Clicking under dash from
Intermittently, when trying to start the car, I get a clicking noise from behind the glovebox area. After multiple tries, it eventually starts, but it is taking more tries.
I tried taking the car out of park and putting it back in firmly, and occasionally this works, but more often not. Sprayed some WD 40 into the ignition and it helped for a few days, but may be coincidence also.
The battery is new and strong. I checked for corrosion and terminals are clean.
This is like the toothache that goes away at the dentist - I can't get someone to fix it when it won't repeat the symptoms.
I probably can do the repair if I knew what to R & R.
Old 04-11-2008, 06:46 PM
panzer dragoon panzer dragoon is offline
Re: Won't start - Clicking under dash from
how does your car start in neutral?
Old 04-11-2008, 07:08 PM
danyell danyell is offline
can someone help me ,my 98 intrigue won't start niether,I tried a jump start and the lights came on but it did not start.I tried hitting the starter,but the thing is my engin lights was coming on before it stop on me
Danyell
Old 04-11-2008, 10:57 PM
Apparently these cars will only start in Park. At least there is no response to trying to start in neutral while there is a clicking or a start in Park.
Old 04-11-2008, 11:34 PM
try starting it with your foot on the brake = brake needs to be depressed for the car to start. Sometimes the neutral safety switch gets bad = car will start better in either neutral or park.
Are you getting one click or many. toggle the key on and off multiple times and see if that helps.
