Go Back   Automotive Forums Car Chat > Ford > Probe
Old 04-11-2008, 01:39 AM
smeltdan smeltdan is offline
starting
My Daughter has a 1990 Probe LX and when the car is run for awhile and she turns it off and parks. If it is still pretty warm it won't stay running, will start but will run rough and quit. If she let's it cool down it will start and keep running. I need any suggestions on where to start or what to look for.
Thank you.
Old 04-17-2008, 08:44 AM
FORDGUY09's Avatar
FORDGUY09 FORDGUY09 is offline
Send a message via AIM to FORDGUY09 Send a message via MSN to FORDGUY09 Send a message via Yahoo to FORDGUY09
Re: starting
i have had the same problem with my 89 gl i had to replace my fuel regulator and straight wire my fuel pump to the ignition and it fixed my problem but u might have to get a new MAF Air Flow sensor also
good luck
Old 04-17-2008, 11:12 AM
Will Help Will Help is offline
Re: starting
There are several sensors under the hood which can become heat sensitive when they are on the threshold of failing. This condition can come from the heat of the electricity flowing through them or simply the heat of the engine compartment. When you park and shut the engine off, the temperature of the engine and engine compartment will get hotter for a period of time due to the fact the air is no longer flowing through the radiator cooling the water and engine compartment and the water pump is no longer circulating coolant.
The Mass Air Flow sensor will get hotter because no air is being pulled through to cool it by engine vacumn. You can do a quick check of the MAF sensor by running cold water across the housing and see if the problem goes away.
Check to see if you have any trouble codes coming up for any of the sensors.
Also could be caused by the fuel lines getting hot and creating some vapor lock problems.
Does the engine want to diesel ( keep running ruff ) after you shut it off?
Old 04-17-2008, 01:10 PM
Re: starting
engine doesnot continue to run after shut off
Old 04-19-2008, 08:53 PM
FORDGUY09's Avatar
Post Re: starting
another thing to look for is the fuel pump relay or figure out if the fuel pump comes on when she goes to try to start the car back up when engine is still hot if the fuel pump does not come on take out the back seat (2 10mm bolts in front lower seat) and figure out if u have power going to the fuel pump if you dont try to run a straight wire from the battery to 2 of the wires on the fuel pump and see if it kicks on, the 89-92 is obd 1 so try to get a code reader and see if you can pull up any codes on it and post them in here for us
1997 Honda Accord
2003 F250 6.0 ps cclb
2016 jeep patriot
