Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 04-10-2008, 11:30 PM
coojo1960's Avatar
coojo1960 coojo1960 is offline
Lightbulb left front electric window
1994 towncar left front window regulator broke cable is broke window is stuck in the down posistion does any one know how i get get window up temperalry i took panel off and its stuck wont move only about 2 inches or so
Old 04-11-2008, 06:09 AM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Re: left front electric window
You need to unbolt the window from the motor and pull the window up. use a wood shim to hold the window up untill you can get it fixed. The shim is a trick I use in my junk yard to keep the windows up and cars. Many have missing regulators and motors, I like to keep them dry inside and varmits out. I should have a good used regulator, 15.00 plus shipping let me know if interested. Thanks
Mike aka JYD
Old 04-12-2008, 09:38 PM
coojo1960's Avatar
sounds good thanks for the info do you have one with the motor my mechanic said to try to get the whole assembly about the motor removeing it i dont have the tool to get it out theres not very much room tu work with let me know about the regulator with motor if not ill ask mechanic about just the regulator thankyou tom
Old 04-13-2008, 07:22 AM
If the motor is good, I wouldn't replace it. There are three screws that hold the motor to the regulator, I believe they are a square or torx bit head. The motor has to come off the regulator assembly to install or remove. There are holes in the door metal to go through to access the screws, remove the inside door handle and lock slide that will help. I also find it easier to remove the window from the door to have more room to work in there, it is tight. You will have to drill out some rivets to get the regulator assembly out, 1/4 20 bolts can be used to reinstall. I do have some motors if you need them. Let me know if you have any more questions. If I had a good camera and a camera man I would do a how to video on this. Unfortunately I don't have a video camera any more.
Mike aka JYD
Old 04-13-2008, 11:36 AM
coojo1960's Avatar
Question Re: left front electric window
thankyou let me no how much total an where to send money i wont have money till thursday . thankyou tom
Old 04-13-2008, 04:28 PM
Hi Tom
I took some pictures, see link below for the locations where you will need to drill out the rivets. There are two nuts circled at the top location on the regulator. There are also two rivets to drill out where the window connects to the regulator. You will have to have the motor removed so you can move the window down far enough to get to those rivets. Let me know if you want it for sure and I will remove it from the car. The one I took the pictures of will be easy to remove, since it has been replaced already and has been bolted in. I would include all bolts you would need to reinstall.
http://cmasalvage.com/92tc_lfwreg.jpg
Mike aka JYD
Old 04-13-2008, 08:56 PM
coojo1960's Avatar
Thumbs up Re: left front electric window
thanks for doing that i will let you no before friday your a lota help . thanks tom
