Old 04-10-2008, 08:37 PM
Sunni Sunni is offline
Frusterated
the other day i got my stealth running and i took it for a 2 mile drive parked it out front of my house and shut it down got up next morning to head into work and the damn thing didnt start so i hot wired the fuel pump ran all day than i shut it off that night again parked in front of my house and this morning it didnt start it gots plenty of fuel pressure but its too windy today to sit outside and check for spark so ima wait till tomorrow to check the spark any other ideas why it wouldnt start and go out just like that over night? 93 dohc
Old 04-10-2008, 09:52 PM
new2mitsu new2mitsu is offline
Re: Frusterated
fuked up ecu?
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 04-10-2008, 10:51 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Frusterated
ECU could very well be a culprit.
Old 04-12-2008, 11:03 AM
Re: Frusterated
where is the ecu located?
Old 04-12-2008, 01:22 PM
Re: Frusterated
the ECU is behind the radio. jus pop of the carpet on both sides of the console, and there are 4 screws that hold it in i believe. 2 on each side. jus undo the screws and unplug the wire harness and it should slide right off. once you get it off take out the 4 screws that hold the top on, and remove the top. then check the capacitors for leakage
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 04-12-2008, 04:32 PM
Re: Frusterated
check them for leakage with like a tester or just broken wires? how would i know if they are leaking?
Old 04-12-2008, 05:37 PM
Re: Frusterated
you can actually see crap coming out of the caps
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 04-12-2008, 06:51 PM
Re: Frusterated
there is no crap comin out of the caps
Old 04-12-2008, 06:55 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Re: Frusterated
Check carefully, there could only be a little bit leaking, it looks like brown slime really, do a search on www.stealth316.com and they have some pictures of leaking capacitors on our ecu. very common problem. otherwise you could check your MFI relay but those dont go out as often as the ecu's
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 04-12-2008, 07:49 PM
Re: Frusterated
ty i found the brown goo is it cheaper to buy one on ebay or bring it in to be fixed?
Old 04-12-2008, 07:59 PM
Re: Frusterated
does it matter which md# it is or should i look for one with the same number? md188204
e2t35681
3224 t1
and on the side it says 8204
Old 04-12-2008, 08:09 PM
Stealthee's Avatar
Re: Frusterated
all that matters is that its from a 91-93 DOHC NA
