Old 04-10-2008, 04:38 PM
BabyCavyZ BabyCavyZ is offline
spark plug location...
hey, i just need to no where they are located exactly cause i need to change them. Whether i have to take off the whole manifold or if its only gonna take me 20min or so... thnx
1999 Cavalier Z24 - Visonik 700W Amp, 2 12" Rockford Fosgate P1's, Pioneer Headunit, Magnaflow Dual Exit Exhaust, Magnaflow Cat Converter, Pacesetter Header, AEM Short Ram Intake.
Future Plans: Camshaft, Pulley kit, Clutch kit, B&M short shifter, head and taillights, 15% tint
Old 04-10-2008, 07:57 PM
kirkwood158's Avatar
kirkwood158 kirkwood158 is offline
Re: spark plug location...
under 16 valve dohc signature plate in middle of motor on top . take the 4 10mm bolts loose and out. The wire connector at the right end ignition module remove that set aside. pry cap off and there are your plugs with what is refured to as boots or plug wires . in the middle of the boots is a spring dont loose and have fun..IMO delco plugs , and new boots
IF I JUST DID IT RIGHT THE FIRST TIME
