Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-10-2008, 04:25 PM
TimTim00 TimTim00 is offline
93' civic problems
i have a 93 civic DX that runs good for the most part. but after it warms up the engine starts to shakes when it idles and every so often will stall out when i come to a stop. the spark plugs, spark wires, distributor cap, and rotor are all brand new and are strait from honda. i also checked the vacuum and changed the PCV valve so thats good too. any suggestions would help out alot.
Old 04-20-2008, 06:28 PM
FORDGUY09's Avatar
FORDGUY09 FORDGUY09 is offline
Send a message via AIM to FORDGUY09 Send a message via MSN to FORDGUY09 Send a message via Yahoo to FORDGUY09
Re: 93' civic problems
one thing that you can check out is ur engine mounts, fuel filter/pump, upgrade to NGK plugs and wires
1997 Honda Accord
2003 F250 6.0 ps cclb
2016 jeep patriot
Old 04-22-2008, 07:51 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
I dont think its your motor mounts, or it would be shaking all the time, I would check your fuel filter. and NGK plugs arent an upgrade when thats what Honda recommends
Old 05-05-2008, 10:54 AM
littlen21 littlen21 is offline
This same thing happened with mine. Get a compression tester. Get the compression on all 4 of the cylinders if one of the cylinders has a compression around 20 psi then you have a blown exaust valve. If compression same in all cylinders it is something else.
Old 05-05-2008, 10:59 AM
Kind of a Big Deal
loss of compression could be many things, one of them being a bent exhaust valve. others including but not limited to, bad rings, badly cracked head/block... etc.
Old 11-02-2008, 10:07 PM
JuliusMowanga JuliusMowanga is offline
Send a message via ICQ to JuliusMowanga Send a message via AIM to JuliusMowanga Send a message via MSN to JuliusMowanga Send a message via Yahoo to JuliusMowanga
Chegk the valves,maybe they ae sticky.also try to use fuel injector cleaner fluid.good luck...
Old 11-03-2008, 04:46 AM
Kind of a Big Deal
Old thread... lock
Closed Thread
