Old 04-10-2008, 03:57 PM
HeWhoKillz HeWhoKillz is offline
tire sizing
How do you size tires? You know, so you raise the diameter of the tire by an inch or two, but how do you know how much the width and height changes as you change the diameter?
Old 04-11-2008, 02:59 AM
HeavyJ HeavyJ is offline
Re: tire sizing
Try this: http://www.miata.net/garage/tirecalc.html
Old 04-11-2008, 03:04 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: tire sizing
That's a good tool for calculating sizes.
The way tire sizes work is really dumb, if you ask me.
The first number is the width in milimeters.
The second number is the height of the sidewall, as a percentage of the width.
The third is, of course, the rim size.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-11-2008, 05:20 PM
j cAT j cAT is offline
Re: tire sizing
the most important thing is load capacity......if you change sizes the next is clearance....don't want to blowout tire when going down the hwy if it scrapes wheel wells....when you hit a dip in road...finally compare revs/mile with oem and what you think you want to use....
Old 04-11-2008, 09:03 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: tire sizing
Which is in inches.
So we get metric, a percentage and imperial all in the same sizing.
