Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 04-10-2008, 10:19 AM
abra0101 abra0101 is offline
How To Reset Service Engine Soon ?
I have a 2002 envoy slt and have a problem resetting the service engine soon, this appeared when my fan clutch starts having a problem like reving to high even in low rpm. I tried to find the fault or reset it with my OBD II but dont show no result it only hangs up or just freeze. Please help, if possible I want to fix it myself coz I'm saving money .....
Old 04-10-2008, 12:28 PM
maxwedge maxwedge is offline
A990 racer
Re: How To Reset Service Engine Soon ?
Something is wrong with your scanner , what kind is it?
Old 04-10-2008, 07:11 PM
BRD BRD is offline
I'm no help if the prob is with the scanner. I take it you replaced the f/c? Depending on which version of the f/c you swapped in, you may need to re-flash the PCM. The GM part # for the newer ver f/c starts with 152xxxxx. Good luck.
Old 04-11-2008, 01:05 AM
I Have To Replace The Fan Clutch First Then Re-flush The Pcm, By The Way What Do You Mean Re-flush? Is It An Scanner That Deletes The Faults?
Old 04-11-2008, 10:28 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Some of those cheapo OBD scanners do just that...scan. They won't let you erase saved codes.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-11-2008, 12:41 PM
just been to auto zone today and let them scanned and found out the code which is PO495 but this code does not show in their computer so I've got to drive back home and look at this code and found out its says COOLING FAN SPEED HIGH. The fan clutch at auto zone cost $199.99 + tax and its a lifetime guarantee. Thanks a lot for the help and I'll let you know if its fix
Old 04-12-2008, 08:54 PM
My Car Fixed And Spent Only $216. Thanks For The Help And To This Forum It Help Me A Lot.
Old 04-13-2008, 08:36 AM
A990 racer
Thanks for the update.
