Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-10-2008, 08:09 AM
cwh13 cwh13 is offline
1999 suburban interior light issues
I bought a 1999 suburban used and am having a few issues with it. Soon after I got it home when you drive it the interior lights started flickering and when the keys were pulled they would stay on and drain the battery down. Now they don't flicker but they stay on. The only way to get them off is to use the dome overide button. When they were flickering you could hear a relay chattering in the dash. Is there a relay specifically for the interior lights or does the 1999 classic suburban have a BCM (body control module) light the new body style 1999 trucks. I checked all the door switches and they all seem to be ok.
Thanks,
Chris
Old 04-10-2008, 09:38 AM
777stickman 777stickman is offline
Re: 1999 suburban interior light issues
Your '99 Sub (OBS) does not have a BCM. It does have an Interior Light Control Module located under the center of the I/P which is probably where the relay noise is coming from.
Other components are: Light sw, door sw's, Remote Keyless entry and wiring.
Cheers and Good Luck.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 04-10-2008, 09:50 AM
brcidd's Avatar
brcidd brcidd is offline
I saw this a year ago or so on a '99 Tahoe- it's the LCM (light control module) as mentioned above-- sit down when you price it! Or use a salvage yard- good luck trying to get the salvage yard to tell you if they have it over the phone-- it is not normally catalogued....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 04-10-2008, 11:36 AM
dablonde dablonde is offline
Personally, I just use the dome override switch and leave it since that's really the least of my worries. Of course, you need to be careful with those back barn doors. My daughter's boyfriend left the door open just a tad the other day. Just enough to keep the lights on I guess and I came out to a dead battery on Monday morning. It was 4 yrs old though and wouldn't take a charge, so another $120 had to be shelled out. That's after spending $2,800 two weeks ago on rebuilding the transfer case and purchasing new tires (uneven tire wear blew the case).
Anyway, enough my b-ing. Have fun with your new/used Burb.
Old 04-11-2008, 12:27 AM
Picked up a new lcm from the dealer today. $28 dollars and change. Now I need to find out where it goes. I was up under the dash just now and couldn't find the rascal to save my life. Any more insight to where its located. 777stickman, under the I/P? Instrument panel? Center. I'll take another look but I may not have the right component as I didn't see anything like I purchased.
Thanks,
Chris
Tore the dash apart again. Couldn't find it. I'll head to the library and look through the component location book.
Old 04-11-2008, 09:52 AM
brcidd's Avatar
It is right above the hump-- maybe this will help- it is object #2 in the below photo: to be sure you have the right module- it is a five wire module gray, orange, white, pink, black- this should help you find the right wiring harness.....
[/IMG]
'99 GMC Yukon
Old 04-11-2008, 10:04 AM
I/P=Instrument Panel. Look for 5 wires: Gray, White, Orange, Pink & Black.
57 Chevy 210
Old 05-01-2008, 10:16 AM
clamfoot clamfoot is offline
my 99 suburban Dome lights along with the keyless remote wont work after having replaced door lock actuaters.I have checed fuses and tried resetting transmitter still nothing.Any thoughts here?
Old 05-10-2008, 03:04 PM
odojak odojak is offline
no
Old 05-13-2008, 06:53 PM
chevylove1 chevylove1 is offline
Im suffering the exact same problem. Im looking for the location of the rke so I can start there. I feel your pain.
Old 12-10-2008, 12:02 PM
JKHEND58 JKHEND58 is offline
I was having this same issue. I replaced the front door switches and it cured the problem. Do the switches first. I got mine at the dealer for $10 each. It is an easy fix. You pull the switches from the outside and they will come apart. Then reach under the dash and locate the connector side and unconnect and remove the inside part of the old switch. Feed the connector back through the hole and connect to the new switch. Push the switch back into the hole.
Note: on the passanger side, you will need to remove the glove box. Just pull the hold strap from the left side of the glove box toward you and slip it out of the anchor point. The glove box will now drop out. You may have to flex the right side of the glove box to clear the opening.
Hope this helps someone.
Old 07-12-2011, 10:32 PM
does anyone know how to check a lcm on 99 brb?
Old 07-13-2011, 06:08 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If it was a snake it would have done bite you.
Go to.
POST no. 6
MT
Old 07-13-2011, 07:52 PM
If you mean "how to check the module for good or bad", then there is no procedure in the service manual for that. It would take a schematic of the C/B and considerable skills to do that. The LCM is called a "non-serviceable replacement unit". This means that after you have gone thru 23 steps of checking for power, grounds, wiring, etc, etc, then you replace the module and hope for the best.
57 Chevy 210
