Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 10-16-2001, 11:10 AM
bump909's Avatar
bump909 bump909 is offline
Registered User
motor mounts for p10
argh.. i got a broken motor mount! the one closest to the shift linkage.. would that be considered the rear mount? i need to get a new one and want to make sure i get the right one.
Old 10-16-2001, 06:34 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
If it's the one bolts the the back of the crossmember (which is sounds like it is) the replacement I picked up from Scottsdale Infiniti is part# 11320-64J00. The description is "Insulator".
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 10-17-2001, 09:56 AM
bump909's Avatar
Registered User
thanks Justin.. I appreciate it. that's definitely the one. i mean i can feel the engine moving around in the compartment. i've been babying it since i first started feeling it.. i definitely knew it was the motor mount.
any tips to installing those? i had to put the crossmember in before and it was a bitch. took me forever to line up the bolt with the holes for the insulator mount.
Old 10-17-2001, 04:06 PM
JustinP10's Avatar
Well, for me it's even more of a pain, because I am running a set of energy suspension inserts. They make lining up the rear mount like 100 times more difficult. But, I usually find it easiest to get teh rear mount up and in first, using the crossmeber as a level to get the rear mount into place. Once you get the bolt holes lined up, bolt in the front. if you have a jack, i'd use it to keep the motor in place too, just be very careful where you hold the motor up from, don't want a dented oil pan or anything crappy like that. I think I usually use the tranny. There's a decent place you can sorta hold the motor up with on it. But i'd have to look again to be able to describe it better. Hope this helps.
Justin McClanahan
95 G20
Old 02-04-2005, 11:07 AM
GtRider GtRider is offline
Send a message via AIM to GtRider
If anyone looking for Motor Mounts i know this place in MIAMI
305-331-2710
94 G20t
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
